Suspension Coilovers - help please
Old Oct 25, 2012 | 09:11 AM
  #26
mbwicz's Avatar
mbwicz
See if there are any MINI clubs in your area, there is probably someone in a club that has put coilovers on before.
Also, make sure that the quote for install includes a 4 wheel alignment.
Mike
Old Oct 25, 2012 | 10:34 AM
  #27
submitaweasel's Avatar
submitaweasel
Originally Posted by delete_me
I thought I was set. Talked to Way, had it all figured out. Called Chet's here in Albuquerque.......they quoted me 800-1500 just to install! WTF!?!?!?
Now I have no idea where this will take me. I figured install would be 400-600. Even the Stealership quoted me 800-1000.
Any ideas? I'm not a DIY guy. I've tried in the past and have had a really hard time. I'm not mechanically inclined at all. I'm more of a computer nerd
What is their reasoning behind that ludicrous price? Can't be hours unless theyre outright lying.
Old Oct 27, 2012 | 07:26 AM
  #28
delete_me's Avatar
delete_me
They really didn't give me a reason. I just chuckled. I really have no idea what I'm going to do now. I looked on Craigslist and it was rather scary. I wouldn't trust my car with any of them. I guess I'm leaning toward the dealer installed JCW suspension or taking parts to them to install.
Old Oct 27, 2012 | 08:01 AM
  #29
MikewithaMini's Avatar
MikewithaMini
I did springs (NMa) and shocks (yellow) with rear sway bar (19mm HK) at the local club's diy day recently. The tech directed me and did the springs for me. It took less than 4 hours. The discount price on the alignment at the dealer was $150.
Old Oct 27, 2012 | 11:36 AM
  #30
mbwicz's Avatar
mbwicz
I assume that you don't have the tools or confidence to do this work, here are some things that can make it cheaper to have it installed:
If you buy camber plates, ask Way (or whatever vendor) to fully assemble your front coil overs. This will make it very simple and quick (therefore cheap) to swap out the shock assemblies. By having the front shocks together, you probably save 1 hour of shop time.
Make sure that the rear coil overs are also assembled.
If you let your vendor know your desires for ride height, they can adjust the springs to about the right height. Same for the damping adjustments, if the shocks are adjustable.
Having everything done at once makes a bunch of sense. You will still need an alignment.
All of this work is basic mechanic work with only hand tools required (except for the alignment). I understand if you are nervous to undertake this, but it should be less than a days work, even for a novice. Buying a Bentley manual from Amazon gives detailed descriptions on how to do this. Having the shocks assembled reduces the safety concerns and requirements for specialized tools. There are lots of threads on here that describe how to install these parts, if you want to try it yourself.
Mike
Old Nov 8, 2012 | 06:16 AM
  #31
delete_me's Avatar
delete_me
I still haven't pulled the trigger. Trying to decide between Megan's or ST's. which would improve comfort? Sometimes the stock suspension is pretty harsh. Or should I look at a different coilover?
Still cannot find a decent price for install in Alb. Cheapest thus far is the Stealership (I know WTF).
Thanks!
Old Nov 8, 2012 | 06:22 AM
  #32
Mindspin311's Avatar
Mindspin311
STs for comfort probably
Old Nov 8, 2012 | 07:07 AM
  #33
submitaweasel
Thanks!
Too bad youre not close to me. I'd only charge a 6 pack.
Old Nov 8, 2012 | 10:06 AM
  #34
Jack & Coke's Avatar
Jack & Coke
What factual basis did you come to that conclusion?
Old Nov 8, 2012 | 12:10 PM
  #35
submitaweasel
My guess wouldn't be factual...considering the word "probably." Sounds more subjective to me probably based on experience.
Old Nov 8, 2012 | 03:35 PM
  #36
Creeve's Avatar
Creeve
Well the the STs use the factory rubber bushing top hat and the Megans use steel spherical bearings. So that alone will make a significant difference in comfort.
Old Nov 8, 2012 | 07:50 PM
  #37
delete_me's Avatar
delete_me
Weasel - thanks man! I appreciate the gesture.
Creeve-since I'm suspension stupid so I assume you are saying the STs?
RIchard Nguyen
Sep 14, 2016 11:43 AM
Keet
Suspension
Aug 30, 2016 03:46 PM
sssevita
Mar 20, 2016 06:24 AM
CooperSharp
Oct 12, 2015 09:21 AM
gnhovis
Sep 28, 2015 10:56 AM
