Suspension Rear Camber Arm
Old Oct 17, 2012 | 08:25 PM
socal805's Avatar
socal805
Rear Camber Arm
I ordered the HR Springs this afternoon. While doing so my installer mentioned that after the install and they get it on the alignment/camber machine there is a chance we might need to get a rear camber arm if there is not enough adjustment to get it set correctly. They said we will have to wait and see. These guys are experienced installers.
I was curious if any of you who have installed springs on your CMS 4 had enough adjustment to get the rear camber correct, or did you need to add a rear camber arm.
If I go with a rear camber arm I am looking at SPC Mini Rear Camber Arm
Looking at the H&R Project car set up they did not use a rear camber arm H&R Project Car so I am hoping it is not necessary to obtain the needed amount of adjustment.
Old Oct 17, 2012 | 09:10 PM
WayMotorWorks's Avatar
WayMotorWorks
Vendor
Yes you will need rear adjustable control arms to get the rear camber correct.
I suggest the Hsport rear camber links as we have had customers using them for 9+ years without failure, and we use them on the race cars too.
Old Oct 18, 2012 | 09:13 AM
MotoGreg's Avatar
MotoGreg
If you have a race car then the Hsport are good. But for a street car you want the SPC.
The lowering springs will increase your rear camber to close to -3* and you will need adjustable arms to adjust it back to a reasonable amount. The stock adjuster only allows for a very slight range of adjustment.
There is already a thread about this... https://www.northamericanmotoring.co...trol-arms.html
Can you do us a favor and snap a couple of quick photos of the springs, and post them, before you have them installed?
Old Oct 18, 2012 | 09:21 AM
socal805's Avatar
socal805
Thanks Motogreg. I did look before creating a new thread, but obviously missed that thread.
Admin- you are welcome to reduce clutter and close/delete/merge this thread as you see fit.
W0TM8
Dec 19, 2019 07:50 AM
ebowling
90
Aug 4, 2019 09:15 AM
Minibeagle
Aug 13, 2015 10:00 AM
OutMotoring
Aug 6, 2015 09:32 AM
