Suspension Lowering and negative camber answers (no rear adjustable control arms needed!)
Old Oct 1, 2013 | 06:06 PM
  #26
librayiu's Avatar
librayiu
R53 has no eccentric bolt?
R56 or later should hv bigger range for adjustment with the eccentric bolt.
Old Oct 1, 2013 | 06:10 PM
  #27
greenminiclub's Avatar
greenminiclub
It does, at least late 05 and 06, -1.8 was cranked all the way in. Now looking for non-heim joint camber links.
Old Oct 1, 2013 | 06:28 PM
  #28
librayiu's Avatar
librayiu
-1.8 should be fine as factory spec is around 1.7 degree I guess.
Old Oct 1, 2013 | 06:41 PM
  #29
greenminiclub
For Autox I would like it to be close to -1.2
Old Oct 3, 2013 | 09:07 AM
  #30
borderwave2's Avatar
borderwave2
I have found a picture of an R56 challenge car which is lowered without using adjustable drop links. Do they do this to get as much camber as possible?
Old May 11, 2018 | 07:40 PM
  #31
carlitosgaray's Avatar
carlitosgaray
Support trailing arm from underneath using a workshop jack.
Release nut and remove screws (1).
Installation note:
Replace self-locking nut.
Tightening torque 33 32 1AZ.
Mark position of eccentric adjustment washer to trailing arm to simplify subsequent adjustment of rear axle.
Release screw (2).
Installation note:
Refit eccentric adjustment washer.
Tightening torque 33 32 2AZ.
Old May 14, 2018 | 08:25 AM
  #32
Subw00er's Avatar
Subw00er
I love old thread revivals. What front and rear specs are you guys running?
Im about to get an alignment. I was thinking zero toe and caster front and rear and -1.2 to -1.5 rear camber (have -1 camber with ireland plates up front).
Old Apr 24, 2019 | 09:26 AM
  #33
weaverpsu's Avatar
weaverpsu
I am about to pull the trigger on lowering my car but I'm concerned about costs. If I have to buy springs and then also buy rear control arms and then pay for install and alignment, now we are talking a lot more money. I read several threads about people saying some had to and some didn't. Problem is, I don't want to have springs installed, then get alignment, then have to buy control arms, and then pay again. I was told definitively that you don't need them from a reputable source and this thread seems to back that up to an extent. I have an R60 so I'm not sure if everything is the same either. Thanks.
Also, I have seen a disclaimer directly on websites that sell lowering springs that you will need the control arms. Just adding more confusion.
Old Jul 11, 2019 | 02:46 AM
  #34
user 46590's Avatar
user 46590
Just lowered my 09 MCS R57 using the Bilstein B12 kit ( B8 struts and shocks + Eibach lowering springs ).
Did an alignment after on a Hunter system - LR and RR camber came in at -1.32.
I did not change the factory control arms, all stock.
after
on the Hunter
LR
RR
alignment spec, needed front toe adjustment
Old Aug 6, 2019 | 02:13 PM
  #35
weaverpsu's Avatar
weaverpsu
Looks great!
Toolman
Jan 20, 2016 06:50 AM
wkp1219
Nov 13, 2015 07:52 AM
maestro39
Oct 27, 2015 02:38 PM
Minibeagle
Aug 13, 2015 10:00 AM
OutMotoring
Aug 6, 2015 09:32 AM
