Suspension R50 diagonal strut braces on R53
Old Dec 6, 2011 | 06:44 PM
astroBlackMetallic_Mini's Avatar
So, again in the interest of "cheap mods", my research has led me to these bad boys:
http://www.minimotors.com/Mini_Coope...649&pID=114721
They are the convertible strut braces for the engine. They "should" bolt right on to a R53. I have checked, and there are ports for where these bolts should go. They are just currently covered with little caps.
The only issue I see with the install, is with the driver side brace. The bottom of it bolts to a spot that is currently being used for a bracket for the AC line or something.
Has anyone else done this mod?!?! It looks so easy and it's so affordable!
Old Dec 8, 2011 | 11:56 PM
alx873's Avatar
alx873
ya this mod is pretty popular, takes out a little front end clicks and ticks in the cabin. I can't see it doing much else suspension wise, but it helped with the NVH, in my R53. Get it if you can afford it, why not, it's cheap
Old Dec 9, 2011 | 05:09 AM
ZippyNH's Avatar
ZippyNH
They are actualy from a r52...
Cars build after mid 2004 should have the bolt holes...
very common mod
lots of threads, helped with nvh, and a few rattles....
Old Dec 9, 2011 | 05:16 AM
ZippyNH's Avatar
ZippyNH
PS
That hole on the drivers side is a non issue...
When you do the install, it is very tight, but you will find another hole down there if i remember right.
Old Dec 9, 2011 | 05:41 AM
SimTechDJ's Avatar
SimTechDJ
my R53 is a 09/03 build and has the threaded holes.
Old Dec 10, 2011 | 09:47 AM
Applesauce's Avatar
Applesauce
As others have said, these are OEM R52 hardware. They're among the best $35 I ever spent, I'd say... Definitely a noticeable improvement in chassis stiffness and a welcome reduction in dashboard creaks and cracks and pops and squeaks. Still nowhere near quiet, but much better! You'll need a handful of M6x1x<15 hardware to install them; I treated mine with blue Loctite.
Take this with a grain of salt, but know that I'm a mod sceptic: I don't think my strut tower bar did anything, I'm certain my rear stress bar did absolutely nothing, and I have my doubts about the utility of sway-bar end links. But I'm also convinced that OE engineers, with kajillions of dollars for R and D, get things much more right than professional aftermarket tinkerers.
Old Dec 10, 2011 | 03:27 PM
ZippyNH's Avatar
ZippyNH
+1
It is good to hear exactly what i have thought, and sometimes posted!
i know wmw includes the needed bolts....only negative are they are torix if i remember right, so they appear 100%, right down to the bolts..
he can even powdercoat them for folks who want color other than oem black...
Mikli
R55 :: Clubman Talk (2008+)
Jun 26, 2019 05:58 AM
Dec 23, 2015 10:36 AM
JaysinStrife
Suspension
Sep 7, 2015 12:52 PM
ClayTaylorNC
Aug 10, 2015 09:19 PM
