Suspension Snags in STD installation, and some thoughts...
Old Sep 8, 2011 | 08:16 AM
Applesauce's Avatar
Applesauce
I installed my Craven STDs this weekend, and hit a few snags. Just thought I would share... I apparently couldn't hammer the strut tower tops back flat enough - even using a bare hammer, no two-by-four - and they were still too deformed when I went about torquing down the STDs. This is an important step, and doesn't get enough press. I didn't even realize how deformed my towers were (I'm the third owner in a place with really crappy roads) until I laid the STDs on top!
I snapped off one strut tower bolt, and visibly stretched two others, before even approaching proper or adequate torque. I pounded these out, which wasn't easy. Luckily I had some 12.9-grade metric hardware (button-head 5mm hex socket, M8x1.25x20) hanging around, and managed to tape one to a 5mm allen wrench and thread my skinny hand up through the spring... Voilà! These bolts are disgustingly strong and hard, and I plan on popping the other three out in the near future and replacing all of BMW's stock hardware, just in case I damaged other bolts - highly likely, given the looks of those I removed.
So if your Mini has received a good whooping by previous owners and you're feeling late to installing the Craven STDs, consider replacing all the stock strut tower bolts - just six of them in total. I got my 12.9 hardware from Acklands, but any good hardware shop should have a fair selection. I also applied blue thread locker to these to prevent them from unthreading first, should I even need to remove the 7/8" bolts up top.
Old Sep 18, 2011 | 03:55 PM
Carmichael's Avatar
Carmichael
I used a rubber mallet at the end of a really crappy day. Worked well for me!
I installed a Whiteline strut brace after I'd pounded everything straight. The eBay camber plates that I bought ($160 shipped) had strong enough hardware.
Old Apr 5, 2012 | 07:03 PM
BillyCuth's Avatar
BillyCuth
Found your thread applesauce. You didn't detail what you did to knock the old ones out.
adrchn
Aug 13, 2019 02:11 AM
minimofo
Nov 5, 2015 08:40 AM
minimofo
Oct 25, 2015 05:53 PM
minimofo
Sep 9, 2015 10:29 AM
