Suspension Double-Adjustable Shocks For Sale
Old Jun 1, 2011 | 01:56 PM
mitchman's Avatar
mitchman
Just thought I'd drum up some possible interest in some shocks I have for sale. They were used on our 2006 Mini Cooper S that we've recently sold. They are Leda brand shocks that were custom made to be a direct replacement for the stock shocks. They were amazing shocks. Combined with a smaller front sway bar, the car was very balanced with virtually no wheel spin exiting corners.
https://www.northamericanmotoring.co...t/18451/cat/22
More photos/info available here:
http://web.me.com/mitchman/mini-parts/Items/Items.html
Old Jun 7, 2011 | 12:21 PM
chadtoolio's Avatar
chadtoolio
Mitch,
You still AutoX? I would be interested in these if they were coilovers....I am in need of more Camber in the front(springs are hitting the unibody) and my tire temps show the outsides are doing more work. Did you change class? Go with other struts/coilovers. Looking for opinions from fellow Autocrosser/racers, etc...
Thanks, Chad
Old Jun 7, 2011 | 02:14 PM
mitchman's Avatar
mitchman
Yes, I still autocross. I just switched back to RWD (Miata). I miss the power of the Mini though.
You could easily use these as coilovers. You'd just have to buy the standard threaded coilover sleeves (very cheap) that slide over the shock body, springs, and camber plates. The dimensions of these shocks are the exact same as the stock shocks (or a set of Koni Sports for example). So all the same hardware that can be used with those shocks can be used with these. Of course these shocks as WAY better than Koni sports.....just say'n.
Honestly, you could argue that using the coilover sleeves is a better way to go if you drive the car in snow, ice, mud, etc... When the threads get gummed up over time, you can just buy new coilover sleeves (cheap!). But if you went with high dollar coilover shocks (Ohilins, AST, etc...) when/if the threads get damaged you can't replace them without replacing the entire shock body.
Does that make sense?
patpatpat
Aug 27, 2015 07:51 AM
Powershift
Aug 16, 2015 05:14 PM
Emnotek
Aug 13, 2015 05:47 PM
M7Speed
R61 :: Paceman Talk
Aug 10, 2015 01:01 PM
M7Speed
Aug 10, 2015 01:00 PM
