Suspension Ireland Engineering Camber plates Left & Right??
Old Oct 14, 2010 | 01:15 PM
Vincent Hill's Avatar
Vincent Hill
Along with the Power Flex Bushings, Inner Ball Joints, Left & Right side Drive Shafts, Steering Rack, Adjustable TSW Rear Bars and Radiator Fan, I also installed the IE 1.25 Negative Camber plates.
I took the car in for an alignment only to find that I had "Positive" Camber. Am I Pissed! I looked at the plates and did not see any markings to show left or right side and thinking that what ever position they are on one side, It will be the same on the other.
Now I am told that I need to switch the plates! I can understand that if I was changing Caster that switching the plates would change the Caster by either moving the strut top backward or Forward, but not left to right?
Anyone else have this problem?
Old Oct 16, 2010 | 09:01 AM
Bimjo's Avatar
Bimjo
Well, think about it… if we examine the driver side camber plate and it's fixed at -1.25° then the tire would lean toward the center of the car by that amount of angle.
Mounting the driver side plate on the passenger side would make the passenger side tire lean away from the center of the car an equal amount, giving you +1.25° of camber.
All other things being equal that is.
Old Oct 18, 2010 | 08:03 AM
Vincent Hill
I understand your thinking, but my thinking was that the plates mounts were Symetrical and what you have on one side is what you have on the other! Yesterday I took the plates off and found that the triangle of Bolts to mount the plates are not pointing inside the center of the car and then left and right , but Front of the car center and then left and right so that what is on the outside on the left is on the inside on the right!
I Ground a "L" and "R" onto the plates and think it is STUPID that they do not come marked since the plates are Identical but one plate is USD to make the difference. I also cannot believe that "Their Lawyers" would say thay it is better not to give any instructions or Mark the Plates as opposed to them being installed wrong and make the car Less Safe?
W0TM8
Dec 19, 2019 07:50 AM
Hippiehobbit267
Dec 3, 2019 04:22 PM
Minibeagle
Aug 13, 2015 10:00 AM
ClayTaylorNC
Aug 10, 2015 09:19 PM
OutMotoring
Aug 6, 2015 09:32 AM
