Suspension Aftermarket lowering springs
Old Sep 15, 2010 | 01:14 AM
Driv3r's Avatar
Driv3r
My rear's seemed to have been negative cambered after I had my springs installed. Does lowering kits do this to the MCS or did the guys at the alignment shop do this?
Old Sep 15, 2010 | 02:03 AM
CRoth's Avatar
CRoth
Yes, it's normal for you to get negative camber when lowering. The most effected is the rear. You need to invest in some adjustable lower control arms for the rear. I went with the H-Sports. If you don't fix tge negative camber you will eventually wear the insides of your tires out.
Old Sep 15, 2010 | 09:16 AM
quikmni's Avatar
quikmni
Depending on how much you lowered the car and the year of your MCS, you might be able to adjust the rear camber to make it acceptable without aftermarket lower control arms.
I would suggest around -1.5 degrees camber to keep the inside edge from wearing too fast.
The 2005 and newer MCS have some adjustment on the rear lower control arms. However, if you lowered more than about 3/4" you probably cannot adjust out enough of the negative camber with the stock adjuster and will need a set of adjustable lower control arms. H-Sport (Hotchkis) and TSW are good arms.
Old Sep 18, 2010 | 06:13 AM
Driv3r's Avatar
Driv3r
my right rear seems to be more cambered than the left rear :(
Should i take it back to the alignment place to sort out?
P.S its an '03 mini
Old Sep 18, 2010 | 09:42 AM
quikmni's Avatar
quikmni
The camber on your 03 MCS is not adjustable so there is not much the alignment shop can do to even out the camber side to side. Only the rear toe is adjustable.
Sounds like you will need to purchase adjustable lower rear control arms so that the rear camber can be adjusted.
jeremy_reyes94
Sep 6, 2019 07:53 AM
melscoop
Mar 30, 2016 06:56 PM
G1HQ
Aug 28, 2015 01:41 PM
yukinoinu
15
Aug 24, 2015 09:20 AM
Emnotek
Aug 13, 2015 05:47 PM
