Suspension Is there any advantage to having new steering rack poly bushings put in?
Old Jun 17, 2010 | 11:24 AM
Aeromax's Avatar
Aeromax
I'm having a new steering rack put in soon. So while it's out, is there any sort of advantage to putting a poly bushing in place of the old one? My guess is no, but just wanted to be sure.
Old Jun 17, 2010 | 05:12 PM
MINI33342's Avatar
MINI33342
Depends......are the old ones worn?
If so it might be a good idea to change them to the poly's if you don't mind a bit more vibration at the wheel. They will last much longer than the oEM ones did.
Old Jun 20, 2010 | 08:49 PM
WayMotorWorks's Avatar
WayMotorWorks
Vendor
The Powerflex steering rack bushing is such a cheap mod, it def. can't hurt since you have the rack out.
http://www.waymotorworks.com/powerfl...k-bushing.html
Old Jun 20, 2010 | 11:11 PM
Mike S's Avatar
Mike S
To be honest I can't feel any difference, but the poly will definitely last longer. My old rubber ones were quite brittle by the time I removed them. Old age
I put the poly version in while I had the poly engine mounts put in just for peace of mind.
Old Jun 21, 2010 | 04:46 PM
onasled's Avatar
onasled
Since one side of the rack is directly bolted to the subframe, there is just no reason that changing to poly on that other side.
silence2-38554
Nov 12, 2015 09:39 AM
minipopkart
Aug 13, 2015 05:22 AM
Aug 12, 2015 01:24 PM
PelicanParts.com
Aug 4, 2015 02:45 PM
