Suspension BC Racing r56 coilover review
Old Feb 4, 2013 | 06:44 PM
  #26
Purie's Avatar
Purie
I'd like to see some updates from the people that have these as well since a good amount of time has passed.
I'm suspicious of the BC/Megans camber plates though. I think the camber plate is mounted beneath the actual strut tower assembly. I'd be afraid of that creating flex and raising the vehicle and losing the stroke of the damper. Can anyone verify this?
Old Feb 5, 2013 | 07:41 AM
  #27
andyroo's Avatar
andyroo
All camber plates for Mini mount the same way. It's fine.
Old Feb 5, 2013 | 11:33 AM
  #28
geekswrath's Avatar
geekswrath
Had my BC's on now for about 2 maybe close to 3 years now and they perform pretty much the same as when i first installed them. I've tweaked the ride height over the years, played with preload, messed with the damper adjustment, and other than an issue with the crappy top bearing plate on the old style coils I don't have anything bad to say about mine.
They do ride pretty harsh on surface streets but on smoother highways I have no complaints, I think my dampening is set somewhere around 5 clicks from hardest too.
The adjustable camber plates have really let me get the front alignment where I want it too. I'm about maxed for negative camber and to do much more would have to trim the upper strut mount opening to get at the bolts.
Ferris is a daily driver with the occasional spirited weekend, track day, or autocross.
Old Feb 5, 2013 | 04:23 PM
  #29
Purie's Avatar
Purie
Thanks, BC's are back on my list.
Cheers
Old Feb 11, 2013 | 04:18 AM
  #30
Tweedbean's Avatar
Tweedbean
Any pics of how low you can go on BC's? Not looking to change the springs, but fit them straight out the box after adjusting.
Old Feb 11, 2013 | 05:53 AM
  #31
Creeve's Avatar
Creeve
Here:
About 1/2" from full drop (as low as you can go while still having preload on the springs):
Pretty much as low as they go:
Old Feb 11, 2013 | 06:18 AM
  #32
Tweedbean's Avatar
Tweedbean
Thats low enough for me, especially if they are on 17" wheels.
Old Feb 11, 2013 | 06:51 AM
  #33
Creeve's Avatar
Creeve
Both cars pictured are on 17s
Old Feb 11, 2013 | 08:34 AM
  #34
Tweedbean's Avatar
Tweedbean
Definitely ordering a set then Thanks for the help.
Old Feb 16, 2013 | 10:53 AM
  #35
corin.mcblide's Avatar
corin.mcblide
@creve: did you install the rear adjustment extension?
Old Feb 17, 2013 | 08:16 AM
  #36
JoAhJoAh's Avatar
JoAhJoAh
Whats a great site to get a set of these????
If its not to rude to ask...
Old Feb 17, 2013 | 10:13 AM
  #37
seattlent's Avatar
seattlent
got mine from CMS they also have a version with swift springs.
Hippiehobbit267
Dec 3, 2019 04:22 PM
ebowling
90
Aug 4, 2019 09:15 AM
eatsleepautox
Oct 30, 2015 06:46 AM
theblackfalcon
Oct 11, 2015 09:49 AM
luisfv56
Aug 22, 2015 12:42 PM
