Suspension Rubbing under suspension compression
Old May 13, 2010 | 02:53 PM
OPC's Avatar
OPC
RATTUS Deserticus
Setup:
KW V2
17x7 ET40 wheels
215/45-17 tires
5mm H&R spacer (otherwise rub the spring perch by about 2mm)
Drop is ~12.25 axle center to wheel arch apex. [edit]
So my front tires rub the inside of the fender/wheel arch ONLY under suspension compression (driving straight and/or turning). The inside of the black trim and felt liner is worn thin a couple of spots. The tires seem none the worse for the encounter.
Options I'm considering:
205 width tires (will also eliminate the need for the spacers)
Raise the suspension ~0.75inch - would really rather not do this
Live with it.
Any thoughts?
Old May 14, 2010 | 04:44 AM
slinger688's Avatar
slinger688
In my opinion, you are a little too low.
Old May 14, 2010 | 05:54 AM
iwashmycar's Avatar
iwashmycar
live w it. or raise it a bit. or change the camber
Old May 14, 2010 | 07:04 AM
OPC's Avatar
OPC
RATTUS Deserticus
Yeah, my thoughts are trending in this direction. <sigh>
I thought about changing the camber, but I don't think it would prevent rubbing while in a loaded turn.
Old May 14, 2010 | 10:29 AM
iwashmycar's Avatar
iwashmycar
It slightly would to an extent, but probably not enough, unless its a very slight rub.... Then you may be back in spring perch territory too...
Old May 15, 2010 | 04:40 AM
Gilboyto's Avatar
Gilboyto
I rub, although probably a bit worse than you. I run 18x8 et 27 up front and only rub on harder bumps. I have the stock camber. If your suspension has camber plates, you can add a small amount of camber (check clearance inside by the suspension) to eliminate it. I guess Ive just learned to live with it. lol
Doc Pain
Mar 10, 2021 04:50 AM
freeman727
Dec 10, 2017 04:00 AM
wildwestrider
11
Jan 29, 2016 05:06 PM
vulkandino
Oct 31, 2015 08:29 PM
Emnotek
Sep 29, 2015 07:37 AM
