Suspension metal clanking noise
Old Apr 14, 2010 | 08:08 PM
ndylam's Avatar
ndylam
I just installed the H-Sport lower rear control arms, Alta Endlinks, Eibach 19mm rear-swaybar and wheel alignment done. I'm not sure why the rear is making metal clanking noise at low speed from 0-40mph. My initial thought was the endlinks that making the noise but I just want some more opinion on this.
Old Apr 15, 2010 | 06:41 AM
slinger688's Avatar
slinger688
Could be almost anything you installed.
Endlinks and rear sway bar can be noisy. If you have a lift, put the car up. Take each component and move it to see what noise is there. Tighten up everything again. Did you grease up the poly stuff. Lots of grease.
Old Apr 15, 2010 | 09:31 AM
ndylam's Avatar
ndylam
Thanks for the reply. I don't have a lift but I will check it with the jackstands. I put plenty of grease into the poly bushings but wouldn't mind re-grease them again. What kind of grease do I need to buy since I already used up all the grease that came with the parts ?
Old Apr 15, 2010 | 10:00 AM
slinger688's Avatar
slinger688
I use the marine grease but I think different manufacturers seem to like their own.
Old Apr 15, 2010 | 01:55 PM
ndylam's Avatar
ndylam
It turns out that the endlinks were loosen. I guess they never tightened it after the alignment and worst of all they dent the inner wheel curbs, all 4 of them :'(
So much for "we'll take care of you and your car"
Old Apr 15, 2010 | 02:53 PM
slinger688's Avatar
slinger688
Don't overtighten them as there has to be some movement in the eyelets...
Unfortunately, they were sloppy with their work.
Old Apr 15, 2010 | 03:45 PM
etalj's Avatar
etalj
Our endlinks are tricky
Filmy
15
Jun 6, 2023 06:27 AM
BernieCoop
Sep 10, 2021 03:15 AM
keen
Nov 14, 2015 02:08 PM
Sc00terbum
Sep 11, 2015 07:17 AM
Sep 3, 2015 02:06 PM
