Suspension Help confirming shaft diameter...
Old Mar 20, 2010 | 04:51 PM
///Mflossin's Avatar
///Mflossin
Hi guys! I purchased the special socket with cutout window to remove the top nut on the stock strut and I just purchased a set of Bilsteins. I have a few concerns. I spent $55 on this tool but I am starting to wonder if the bilstein shaft is 14mm as opposed to the stock 12mm. If this is the case, the OD on the top nut will likely be 22mm as opposed to 21mm. This is a concern...can anybody confirm this? I absolutely refuse to use air tools on this nut regardless of it being a common practice. Thank you very much in advance for the help!
Old Mar 23, 2010 | 08:19 AM
TerryD's Avatar
TerryD
Use air tools
Old Mar 23, 2010 | 09:36 AM
///Mflossin
Originally Posted by TerryD
Use air tools
No thanks....bought a 21 and 22mm window socket(s). I don't use air tools...just don't care for them.
Old Mar 24, 2010 | 12:04 PM
TerryD's Avatar
TerryD
Drat those new fangled thing-a-ma-jigs.
Alpha Motoring
Sep 7, 2020 07:34 PM
Supertractor3
Apr 7, 2017 11:16 AM
QuickCooper
Dec 29, 2016 06:46 PM
Mazarin
Electrical
Dec 7, 2015 08:23 AM
jennster
Sep 28, 2015 06:19 PM
