Suspension Bump steer NOT helped with new poly bushings.
Today I tried adjusting the pressure of my tires. I experimented with a few settings and settled on 35 psi for all four. It does make a noticeable positive difference, indeed! It feels a touch sloppier on the curves, but barely noticeable, and the tradeoff in not feeling like someone else is taking control of my steering wheel is worth it in spades.
Hard for me to imagine why MINI recommends 38 psi -- even only 3 psi less makes the car much easier to deal with.
This car has been a great learning experience in many different ways. Unfortunately, the driver's course I tried to sign up for at Willow Springs next weekend is full, but I'm looking forward to taking a class at some point and learning even more.
There is also a patch in a curve on a road that I drive frequently that extends all the way across the lane (they installed a water line across the road). If I hit this patch with any power the car will hop to the outside. Not sure what this is called.
Of course, bump steer is a geometry issue. It has to do with the relationship of the rack, differences of steering arms etc. I recommend the old Fred Punn book How To Make Your Car Handle as he has excellent pictures. Then you can see why everyone who changes the ride height complains about bump steer. The problem is caused by not understanding what you are changing. A strut suspension will ALWAYS have bump steer unless you ran the steering arms of the top bearing. The manyfactures attempt to minimize it at standard ride height.
Interesting. No steering arms shown. There is still no way to maintain exact proportions of steering arm lengths with respect to the virtual arm lengths as you are still following the strut. You will still have some bump steer. Zero bump steer is only possible with paralell arms. Not a usual configuration. One only hopes the OEM did their best so it is not too bad.
R50/53 Guidance on selling a 2005 S
Toolman
Jan 20, 2016 06:50 AM
silence2-38554
Nov 12, 2015 09:39 AM
minipopkart
Aug 13, 2015 05:22 AM
PelicanParts.com
Aug 4, 2015 02:45 PM
