Suspension Best suspension for my situation
Old Feb 18, 2010 | 09:00 PM
  #26
etalj's Avatar
etalj
I'll see what I can do!
Originally Posted by JamesHunt
In germany go to colonge and visit pasha in spain go the the riviera club near barcelona
i will. Thanks for the tips. Definitely want to head down to the Ring.
Old Feb 19, 2010 | 06:07 AM
  #27
andyroo's Avatar
andyroo
KW texas speedworks are very expensive for a twintube coilover that can not be revalved or rebuilt.
They can be rebuilt....in fact pretty soon my shop will be an authorized KW rebuild facility. Don't know if we can touch TSW's stuff though.
I think they are fairly priced.
Under 2k I'd look at Bilstein PSS9, Eibach, or TSW KW's.
TSW's are the ONLY lowering spring worth considering IMO....everything else is too low and I'd prefer stock. They'll do well with Koni yellows or Bilsteins, front plates, rear bar, some bushings, etc.
But a coilover is ultimately a better way to go if you can afford it.
- Andrew
Old Feb 19, 2010 | 08:25 AM
  #28
ron-s mini's Avatar
ron-s mini
- Andrew
Is the suspension travel distance the same for each brand on your recommended under 2k list?
Old Feb 19, 2010 | 08:28 AM
  #29
andyroo's Avatar
andyroo
That's something I'd like to find out myself.
I wish more suspension vendors posted total suspension travel and bump/droop at recommended ride heights. Especially since bump is so limited on these cars stock and a gain in bump would be wonderful.
- Andrew
Old Feb 19, 2010 | 12:35 PM
  #30
JamesHunt's Avatar
JamesHunt
Good question.
Old Feb 19, 2010 | 12:38 PM
  #31
andyroo's Avatar
andyroo
What do you mean? Can you not go any higher than 1.2 inches less than stock?
Or do you mean they have the same bump travel as stock when they're 1.2 inches lower?
- Andrew
Old Feb 19, 2010 | 12:59 PM
  #32
ron-s mini's Avatar
ron-s mini
- Andrew
The latter, bump travel after lowering for example:
KW uses shorter damper bodies [about 1.6" shorter] than some other coilovers, which means you can run the car 1.6" lower than stock and have the exact same travel ratio as stock [with 3.3" droop and 1.7" compression], lower ride height and no sacrifice in comfort / performance.
How does this compare to the others you recommended?
Old Feb 19, 2010 | 01:10 PM
  #33
andyroo's Avatar
andyroo
Oh I know....I was responding to James about something else. Sorry for the confusion.
Well no sacrifice in comfort and performance, not taking into account spring rates and valving. Of course it's probably better than stock on both counts....
The Eibach Pro Street's use KW bodies, so they're likely the same as the KW's. TSW's are just revalved KW's.
Bilsteins just visually look like they use shorter bodies, but again i'd like to see it myself and get some numbers. Same with the H&Rs, which use Bilstein dampers but i don't know if they're the same body.
I have no interest in lowering the car 1.6" from stock, but lowering the car a half inch while gaining an *** ton of bump travel is my goal. I might need custom springs to do it if the provided springs are too short. Anyway, my plan is to probably go with Eibach or Koni coilovers with my own custom springs. That will be cheap and ride well. Should perform pretty good. Not very hardcore, but then neither am i.
I can't afford PSS9's and the linear springs i want to go with them, and although I could get the H&R's since it's a cheap, nice inverted monotube Bilstein damper, I'd like to see travel numbers and a shock dyno of them.
- Andrew
Old Feb 21, 2010 | 12:19 PM
  #34
JamesHunt's Avatar
JamesHunt
- Andrew
thought read that kw just exchanged cartridges in the past. good to know .
Old Feb 21, 2010 | 03:42 PM
  #35
etalj's Avatar
etalj
- Andrew
+1.
FWIW I'm going with Eibach Multi-pro R2 with stiffer Swift Springs
Old Feb 21, 2010 | 04:41 PM
  #36
JamesHunt's Avatar
JamesHunt
Originally Posted by etalj
+1.
BIG BANG FOR THE BUCK
Old Feb 22, 2010 | 07:45 AM
  #37
slinger688's Avatar
slinger688
Can anyone help confirm whether Eibach Multipro 1 or 2 can be rebuilt as well.
Thanks.
Old Feb 22, 2010 | 11:26 AM
  #38
redduc's Avatar
redduc
According to the Koni website they have a kit that pairs the FSD's with an eibach lowering spring (1-1.5 drop).
Old Feb 22, 2010 | 11:29 AM
  #39
JamesHunt's Avatar
JamesHunt
Thanks.
Yes the eibach monotube mutipro coilovers can be rebuilt and revalved
Old Feb 22, 2010 | 11:30 AM
  #40
JamesHunt's Avatar
JamesHunt
is the kit for a r56 or a r53 or a different make ?
Old Feb 22, 2010 | 01:19 PM
  #41
redduc's Avatar
redduc
Their web site isn't very good, but when I specified 2009 cooper S it gave FDS's as an option. In the spec's of the shock it states the eibach spring can be used. I would think the ideal (cheap) solution would be FSD's with TSW or NM springs. I'm not really a suspension junky thought, so I am just going off of what I have read.
Old Feb 22, 2010 | 01:29 PM
  #42
JamesHunt's Avatar
JamesHunt
Koni Tech dept said no fsd with lowering springs on any mini cooper. Will fsd work with lowering springs with other cars yes .
Old Feb 22, 2010 | 01:33 PM
  #43
andyroo's Avatar
andyroo
And i'd agree with that....
any 1+ inch drop on fixed perch dampers is gonna be a "for looks" set-up with ride comfort and strut life taking a back seat.
- andrew
Old Feb 22, 2010 | 04:13 PM
  #44
redduc's Avatar
redduc
Gotcha, thanks.
Old Feb 22, 2010 | 04:26 PM
  #45
etalj's Avatar
etalj
I just wonder whether or not I'm stretching the limits by speccing 10kg springs....
Old Feb 22, 2010 | 04:46 PM
  #46
JamesHunt's Avatar
JamesHunt
pretty stiff
Old Feb 22, 2010 | 04:47 PM
  #47
JamesHunt's Avatar
JamesHunt
6k front 7 k rear
Old Feb 22, 2010 | 06:27 PM
  #48
slinger688's Avatar
slinger688
The more I find out, I seem to like the Eibach Multipros. They have adjustments on the bottom of the shocks so you do not have to remove the strut/shock assembly to make changes to a dampening rate.
Like the OP, I am looking for something that can be used for both street and track so it should not be too stiff.
Old Feb 22, 2010 | 06:28 PM
  #49
slinger688's Avatar
slinger688
6k front 7 k rear
Is this a bias toward oversteer?
Old Feb 23, 2010 | 02:04 PM
  #50
etalj's Avatar
etalj
6k front 7 k rear
I think one can afford to go stiffer with Swift Springs, because they're so linear compared to most other springs. I had 6kg springs on my R53, wasn't stiff enough for me....
