Suspension Coilovers
Old Jan 25, 2010 | 09:11 PM
  #26
JamesHunt's Avatar
JamesHunt
Originally Posted by etalj
I thought you were getting ASTs? Did you go for the 450lbs/in and 600lbs/in fr/rr? If so, how are they? I love swift springs, they are just awesome, will probably get them as well.
That's a little disconcerting. What were the real rates vs the promised rates? Were they different side to side, front to rear?
AST would have taken 12+weeks ended up getting the mutipro2 for dealer net thru tirerack .
Multipro 2 with swift springs 400 f 500 r 24.5 mm jcw front bar 19 mm eibach rear bar,powerfex bushings,eibach front camber kit,Nm engineering upper and lower rear control arms(on order).
next up is get the diff installed and 245/40/17 on Complete custom wheels
Old Jan 25, 2010 | 10:04 PM
  #27
andyroo's Avatar
andyroo
What rates did the eibach's come with?
- andrew
Old Jan 25, 2010 | 10:12 PM
  #28
JamesHunt's Avatar
JamesHunt
- andrew
Eibach rep said 280ish front and rear .
Old Jan 25, 2010 | 11:01 PM
  #29
Oxybluecoop's Avatar
Oxybluecoop
My H&R RSS are shot after 60k of being spun all the way down and 14 track days. Overall I was impressed but it's time to move up.
Old Jan 26, 2010 | 03:30 AM
  #30
etalj's Avatar
etalj
That's just too soft. Annoying!That means you've gone up to 9kg on the rears, can the valving keep up with that sort of increase?
Old Jan 26, 2010 | 06:15 AM
  #31
JamesHunt's Avatar
JamesHunt
yes
Old Jan 26, 2010 | 05:54 PM
  #32
Porthos's Avatar
Porthos
I guess there is going to be no sticky for this. I looked at the Eibachs, I never really been a fan of them but they looked good. I just want some nice coilovers I can deal with a stiff ride but, I want something that will handle great.
Old Jan 26, 2010 | 07:54 PM
  #33
andyroo's Avatar
andyroo
What's your price range?
- Andrew
Old Jan 26, 2010 | 07:58 PM
  #34
JamesHunt's Avatar
JamesHunt
I think the prostreet eibach coilover may be what you are looking for . 960 shipped from autoanything .
Old Jan 26, 2010 | 08:03 PM
  #35
Porthos's Avatar
Porthos
between 900 - 1600 is what I am looking a spending. But the Eibachs will be what I get.
Old Jan 26, 2010 | 08:07 PM
  #36
JamesHunt's Avatar
JamesHunt
eibachs prostreet coilover+ hotchkis lower rear controlarms+ powerflex bushings+ front and rear swaybar endlinks=$1555
Old Jan 26, 2010 | 08:29 PM
  #37
andyroo's Avatar
andyroo
^ Yeah that's a good way to go.
Old Jan 26, 2010 | 09:50 PM
  #38
etalj's Avatar
etalj
my future setup will be eibach Multi Pro R2s with 8kg fr and 6.5kg rr Swift springs, TSW lower rear control arms, TSW f&r adjustable endlinks, and Alta PSRS. (yes I know most alta stuff is junk, but I like the idea of spherical FLCA Bushes)
Old Jan 27, 2010 | 05:34 AM
  #39
JamesHunt's Avatar
JamesHunt
Car will understeer with those spring rates. remember jcw's come with a ediff(total junk) if you had a justa cooper s with lsd it would not be as bad,get a giken diff asap.
Old Jan 27, 2010 | 08:15 AM
  #40
andyroo's Avatar
andyroo
I do wish the pro streets came with linear rates though.
And yeah, i'm planning on even rates front and rear (and i'm not that hardcore, not an oversteer junky).
- andrew
Old Jan 27, 2010 | 09:00 AM
  #41
slinger688's Avatar
slinger688
You should add front camber plates to the setup (which the Eibach Multi-pros have). Works well to reduce understeer, especially at -1.8 to -2.
Old Jan 27, 2010 | 05:04 PM
  #42
etalj's Avatar
etalj
Front camber plates are optional, and I will be getting them.
Higher rates up front will probably induce some understeer at lower speeds, but I want high speed stability, with understeer at the limit.
2.5 deg camber front, 1.5 rear
OS Giken Diff will be bought next year (e-diff drives me absolutely crazy with its crappiness)
Old Jan 27, 2010 | 05:19 PM
  #43
JamesHunt's Avatar
JamesHunt
Eibach multipro coilovers come with tophats and they offer a front camber kit that is not a camber plate .
eDIFF sucks so bad that 1st and 2nd gear in my car are useless
Old Jan 27, 2010 | 06:07 PM
  #44
Porthos's Avatar
Porthos
Muhahaha glad I got the mechanical LSD
Old Jan 27, 2010 | 06:18 PM
  #45
JamesHunt's Avatar
JamesHunt
The oem Lsd aint much better,OS Giken FTW
Old Jan 27, 2010 | 07:08 PM
  #46
Porthos's Avatar
Porthos
Ya if you want to spend the money
Old Jan 27, 2010 | 07:18 PM
  #47
JamesHunt's Avatar
JamesHunt
the os giken is a great bang for the buck mod
Old Jan 28, 2010 | 02:35 AM
  #48
etalj's Avatar
etalj
OS Giken is actually quite cheap considering the quality and engineering. The Quaife for my R53 cost me 2k
Old Jan 28, 2010 | 10:00 AM
  #49
countryboyshane's Avatar
countryboyshane
I wish I had a money tree. A big money tree I could water every day in my front yard.
Old Jan 28, 2010 | 01:39 PM
  #50
Porthos's Avatar
Porthos
I will consider it when I do a clutch and flywheel.
