Suspension Front Control Arm Bushings
Old Nov 25, 2009 | 03:39 PM
JENGLAND's Avatar
JENGLAND
Does anybody have a "How To" on changing the front control arm bushings on a R56 yet. I am wanting to change out the front rubber bushings with the PowerFlex bushings and was wanting to know if there are any shortcuts for this procedure.
Old Nov 25, 2009 | 10:02 PM
MINIGURU@WAY MOTOR WORKS's Avatar
Vendor
It's the same as doing an R53, just unbolt the steering rack. Here is a link to a How to:
http://www.motoringalliance.com/foru...sub-frame.html
We also have the Powerflex bushings in stock if you need a set.
www.WayMotorWorks.com 2006 & 2007 NAMCC Overall Champion
Alta,M7,Helix,Wilwood,H-sport,Milltek,CROSS,Craven,DDM,H&R,Megan,Carbotech,EBC,Forge,TSW,Powerflex
Old Jan 21, 2010 | 03:44 PM
JENGLAND's Avatar
JENGLAND
I wanted to thank MiniGuru for the link for replacing the front control arm bushings. I would like to add one thing to process that the instructions left out and that is that there are three bolts holding the steering rack down to the subframe not two as the instructions show. There is a bolt in the middle of the rack that must also be removed or lowering the subframe will pull the rack down with it.
It was also the best upgrade to the car I have done so far. The car is steady as a rock at any speed now and much more percise. Well worth the work.
Old Jan 23, 2010 | 07:14 PM
WayMotorWorks's Avatar
WayMotorWorks
Vendor
Glad your liking them so much, I got the cores back the other day. Let me know what else I can help with in the future.
Old Apr 12, 2011 | 08:45 PM
Step's Avatar
Step
For anyone reaidn this...
just a word of adivce. dont bother playing around with the wrack bolts. just remove your key shake your wheel a bit so the elv locks the wheel and you cant turn it anymore. then remove the 13 mm bolt from under the steering shaft on the inside the car. then remove the tie rod bolts and disconnect the power supply and the wrack will drop right out with the frame.
:-) happy motoring.
Old Jun 6, 2012 | 11:43 AM
cvittas's Avatar
cvittas
The link above is inactive, any help...
Old Jun 6, 2012 | 11:53 AM
JAB 67's Avatar
JAB 67
check www.soopercooperinfo.com
Old Jun 6, 2012 | 12:41 PM
cvittas's Avatar
cvittas
Originally Posted by JAB 67
Checked it, there is only for the 1st Generation Minis..
Old Jun 6, 2012 | 02:39 PM
JAB 67's Avatar
JAB 67
True, but the differences are minor and are described in the thread above.
Old Jun 6, 2012 | 02:50 PM
cvittas's Avatar
cvittas
You are right.. Thanks..
Old Jun 6, 2012 | 02:54 PM
JAB 67's Avatar
JAB 67
You're welcome.
Old Nov 10, 2021 | 07:10 AM
Lex2008's Avatar
Lex2008
I need to do this job after 35k miles on bushings. I changed the end link but the noise returned so here we go again. Last time I had the entire subframe off which Id rather avoid.
I found 2 vids.
W0TM8
Dec 19, 2019 07:50 AM
Toolman
Jan 20, 2016 06:50 AM
maestro39
Oct 27, 2015 02:38 PM
JPMontes3
Aug 23, 2015 01:26 AM
Minibeagle
Aug 13, 2015 10:00 AM
