Suspension Alignment After Rear Sway Bar Install?
Old Oct 19, 2009 | 08:30 AM
Dwight Walhood's Avatar
Dwight Walhood
Putting a H-Sport Comp. rear sway bar on my R56 and need hard advice about alignment after install. Is it needed or not? Can't find a solid answer anywhere.
Old Oct 19, 2009 | 08:41 AM
unclemeat's Avatar
unclemeat
No alignment needed unless you moved something you should not have. Take your time when bolting the subframe back up - center all bolts back to where they started.
Old Oct 19, 2009 | 10:04 AM
Dwight Walhood
THANK YOU SOOOO MUCH! That subframe was the source of my worries. Besides blood loss, all I have to worry about now is when will the UPS truck arrive??
Old Oct 19, 2009 | 02:43 PM
veggivet's Avatar
veggivet
If you do the rear control arms you'd need to realign afterward.
Old Oct 19, 2009 | 02:58 PM
Dwight Walhood
YIPEEE! It came an hour after I posted the above. Beavering time.
minipopkart
Aug 13, 2015 05:22 AM
nomar116
Aug 10, 2015 11:24 PM
ClayTaylorNC
Aug 10, 2015 09:19 PM
OutMotoring
Aug 6, 2015 09:32 AM
