Suspension Suspension Bushings
Old Jun 19, 2009 | 09:14 PM
  #76
jhiggs26's Avatar
jhiggs26
Freedom of movement of my lower control arms with powerflex bushings seemed fine to me.
Neat comparison video on the offset bushings vs. stock Greg!
Jeremy
Old Jun 19, 2009 | 09:19 PM
  #77
Dr Obnxs's Avatar
Dr Obnxs
Originally Posted by meb
Greg...good movie...mine will be different, I'll be nude...dunno what the hell that is I keep tripping over
Originally Posted by Partsman
Sorry Michael, I did read your thread about cleaning/lubing your bushings, I just forgot.
I guess that means he was tripping over his bushings!
Matt
Old Jun 20, 2009 | 04:32 AM
  #78
BlimeyCabrio's Avatar
BlimeyCabrio
Takes some bushings grande to post some of this stuff.
Old Jun 20, 2009 | 07:46 AM
  #79
cristo's Avatar
cristo
Alliance Member
Originally Posted by onasled
OK, here is a video. Excuse my babbling. A little embarrassing... I do know that in watching it again that my spewed facts are not all that accurate, but there was no rehearsal...
I in no way feel to be an authority on suspension, but I think this might clear up why I have always disliked these hard plastic bushings.
http://www.vimeo.com/5185383
Can't get the video to go. Is it still online?
Old Jun 20, 2009 | 10:16 AM
  #80
DaveVT02S's Avatar
DaveVT02S
I just got it to play...
Old Jun 21, 2009 | 09:48 AM
  #81
cristo's Avatar
cristo
Alliance Member
Still doesn't play for me.
Registered for the site, thinking that would help it work, but it didn't.
Old Jun 21, 2009 | 11:22 AM
  #82
bean's Avatar
bean
the link still works fine for me. you need to see this. it will explain a bit about the MINI's front suspension geometry. it is almost impossible to model. one must almost measure toe and camber as the suspension moves through its range of motion and reverse engineer where the actual pivot points are located. hats off to onasled for taking on this challenge.
Old Jun 21, 2009 | 02:32 PM
  #83
jeffc's Avatar
jeffc
7th Gear
I am getting a mix of powerflex, minimadness and stock to replace my aging bushings. They will be installed on Tuesday so lets hope it works out since I have a 6 hour ride to MOT on Friday.
Old Jun 22, 2009 | 05:15 AM
  #84
onasled's Avatar
onasled
Greg, actually the Mini front suspension is very linier in motion at the wheel. So the toe and camber change is very typical and not abnormal during motion.
This is a bad sketch of just where the R-50, 53 pivot points really are. Real is in red and the misconception is in blue.
Old Jun 22, 2009 | 06:04 AM
  #85
meb's Avatar
meb
I was really just teasing you...and Greg was right...I was in the wine cellar...I do my best work after a couple of glasses...any more and I cannot see my work.
I did not have a chance to make a video, but I'll take a look at the one provided here...yes Matt, tripping over my bush -ing...I need a little trim... eeew!!!
EDIT: I doubt if anyone on here except for meb has moved the control arm to full compression and rebound like Greg did in the video before putting everything back together.
Old Jun 22, 2009 | 09:41 AM
  #86
cristo's Avatar
cristo
Alliance Member
Got it to work on my office computer (which has no speakers), but for some
reason, it won't play on my home computer.
Old Jun 22, 2009 | 10:20 AM
  #87
meb's Avatar
meb
If your sub-frame is off, can you peform a test for me? Raise the sub-frame off the floor...12" should be fine. Raise the LCA as far as it will go then drop it and tell us what it does...I know what mine does, just want a second opinion - for others.
Jeremy
Old Jun 22, 2009 | 09:52 PM
  #88
jhiggs26's Avatar
jhiggs26
Sorry Meb my subframe was off and on last spring.
Travel up and down was fine as I remember(these are not offset bushings). Lots of lube helps too!
Jeremy
Old Jun 23, 2009 | 04:50 AM
  #89
meb's Avatar
meb
Silver, copper...or clear
Old Jun 23, 2009 | 08:30 AM
  #90
DaveVT02S's Avatar
DaveVT02S
I got my bushings yesterday (PowerFlex), going in this week - I'll vid and photo - Just for giggles I might also be able to set-up a 'suspension cam' to show the action of the P/F's 'real-world' that hopefully answers some questions...
Old Jun 25, 2009 | 05:20 AM
  #91
jeffc's Avatar
jeffc
7th Gear
I had the following installed at Tyrol Sorts in Queens:
Madness Front control arm polyurethane bushings
Powerflex Gearbox Mount
Powerflex Steering Rack Mount
I am very happy with ride.
Old Jun 28, 2009 | 09:58 AM
  #92
DaveVT02S's Avatar
DaveVT02S
OK, so I got my PowerFlex's in Friday, then took the time to 'ramp-up' road-testing on Saturday. First things first - I didn't vid the LCA action because (a) I didn't get the front subframe all the way out from underneath the car (jackstands wouldn't permit enough clearance for removal without completely disconnecting the power steering, and the resevoir doesn't just "slide down" behind the engine, at least not in mine), (b) taking my time to make sure everything was right, and (c) wasting a couple of hours trying to remove the outer ball joints / locate a splitter that would work on the MINI, spent 13 hours until I had the car back on the ground, so honestly wasn't in the mood to spend the time documentation would have taken...
However, some observations: the action of the LCA, with the P/F's installed, now has less resistance the farther "off center" it travels than with the (admittedly worn) OEM bushings - through what proved to be the 'normal' range of travel the resistance was minimal, and I mean move-it-up-and-down-w/-my-pinkie minimal, and consistant, with no attempt by the LCA to "re-center" as it would with the OEM - those of you who've wiggled the LCA's w/ the OEM bushings note that the farther it travels the more resistance that builds, and upon release it tries to re-center, right? Actually I noted no change to the resistance (w/ the P/F's) until reaching the travel limit of the inner ball joint, which is (should) be past the point of actual 'operational' travel, so based on this and concerns posted here and elsewear regarding alterations to spring rates I feel the P/F's does allow a 'purer', (more linear) spring and damper action.
Now that I've put a few (street) miles on I can say that the ride has improved, both from a handling perspective but more noticably in the way my MINI handles 'sharp edged' pavement breaks on bad pavement, bridge expansion joints and minor speed bumps (I went looking for them ) - firmer yet less harsh, less noise, less 'drama' - yes, possibly because of the state of the OEM's w/ 62k on them, but they were worn not disintegrated. IMHO the ride and handling is now very much in keeping with character of the MINI...
Additional observation: I tend to have a higher level of both mechanical aptitude and patience than the average person, and at times found this extremely frustrating: unable to get bolts to thread because of the most minor misalingment, inadequate instructions on some removal steps - so this not a DIY project for the faint of heart...
Will post more follow-ups as time and thoughts permit...
Old Jun 28, 2009 | 09:32 PM
  #93
Some Guy's Avatar
Some Guy
Thanks for putting the picture up. I have yet to pull the sub frame off of my car so I havent gotten a real good chance to really stare at the setup and play with it. I now see why this binding issue comes up, very interesting.
Old Jun 29, 2009 | 05:06 AM
  #94
meb's Avatar
meb
your observations mimic mine...and only once in the few times that I removed the sub-frame did I have trouble aligning the sub-frame...it was frustrating but I took a few steps back and started over and all was fine.
Glad it all worked out.
Old Jun 29, 2009 | 06:59 AM
  #95
DaveVT02S's Avatar
DaveVT02S
Thanks! Actually the subframe itself went back in suprisingly well - the biggest issue I had was getting the bolts to 'catch' when installing the second LCA bushing bracket; it seemed that the sway bar bushings against the 'collars' on the bar were fighting the correct alignment of the bolts, and, of course, working under the car on jackstands limited my visability, as well as trying to be careful not to cross-thread the bolts, at the same time holding the LCA bracket in place, etc. all with one hand while using the other hand to try to start the bolt - just those 2 bolts must have taken me about 1/2 hour (yes, including a couple of walks away from the car to calm down ) until I got 'em, but they fought me, and I won ... I also had a small issue with the lower motor mount hanging up, but a tap-tap w/ the hammer and it popped into place - and boy was getting the steering-shaft-to-rack bracket apart and back together, ah, 'fun' (limited space for both hands and wrench, combined with surface rust of the bracket made it difficult to get into place to allow insertion of the bolt - of anything that's the one part - the 'knuckle' - that should be PB Blaster'ed ahead of time)...
Side note: regarding wheel alignment afterword, I've still to have it checked, but roadtesting shows no wander at 60+ mph, and stops (both hard and easy) from 30+ with no hands on the wheel are dead straight - now I can wait a little until I can complete my research and have it done to 'my' spec.s...
Before I forget I'd like to thank everybody who contributes to this subject, agree or disagree, it all helped ...
Old Jun 29, 2009 | 12:14 PM
  #96
GOTCURVES's Avatar
GOTCURVES
My personal take on this control arm bushing job is;
It's much faster with 2 people work together than 1 and if you have 2 people the sub -frame does not need to come completely off. You can take a axe handle and pry (slightly) on the sub-frame just enough to slip the rear bolt of the bracket out of place. Re-assymbly went smooth. But definately not a job for someone with limited automotive knowledge and tools.
Old Jun 29, 2009 | 04:08 PM
  #97
minimarks's Avatar
minimarks
Just got the Powerflex bushings in and the motorsport kit with them. What is everyone's thoughts on the additional kit, not sure if I want to put them on or just do the bushings by themselves?
Old Jun 30, 2009 | 07:12 AM
  #98
jayxx83's Avatar
jayxx83
how about these instead of the powerflex
http://www.superflex.co.uk/photopage.php?part_id=130
these look to be different to the power flex versions and are fitted by the leading tuners here in the uk.
Old Jun 30, 2009 | 07:17 AM
  #99
Dr Obnxs's Avatar
Dr Obnxs
They should work...
cause the center piece can rotate. Another way to skin the cat!
Matt
Old Jun 30, 2009 | 07:45 AM
  #100
meb's Avatar
meb
Same concept as Powerflex
