Suspension KW V1 Basic more or less comfort???
Old Apr 6, 2009 | 11:14 PM
  #26
amazingrando's Avatar
amazingrando
Auto on Sport Button guy
I just finished doing a spring swap on my cross coilovers this weekend with a set of Swift springs and WOW am I glad I did. These may be just about the most accurate spring you can get your hands on. Swift uses less coils in the same length of spring to get the job done. For instance, in the rears, the stock cross springs have about 7 coilds, where as the Swifts use 6. I would have to double check to be sure, but you get my point. More spring travel before the spring is binding on itself. Not that I know of this being an issue with the crosses, but I understand it is with BC/Megan. Overall, what I wanted was a slightly softer ride, besides I get bored and like to try out new things. I purchased these from forum member Ninjlao, and while I really can't comment on anything ofther than daily driving comfort so far (It's only been 2 day now) I can tell you that the crosses set up this way make for a noticeably more comfy, compliant daily ride, with plenty of room to frim it up with the damper adjuster. I opted to go with slightly different spring rate than what comes stock with the crosses. Stock cross set up is 8kg front 7kg rear. I went with 8kg front 6kg rear for the Swift.
A little required reading....
https://www.northamericanmotoring.co...gs-dynoed.html
Old Apr 8, 2009 | 11:23 AM
  #27
kreative's Avatar
kreative
Originally Posted by Bezlar
I just ordered a set of these from TSW. I'm going to be installing them myself. Do I need anything special like drop links, or can I just throw them on and get allignement done at a later time. Going for about 1.5 drop.
I believe TSW's will only drop you ~1". H&R's will get you closer @ 1.4"
Old Apr 8, 2009 | 02:32 PM
  #28
Ryephile's Avatar
Ryephile
Originally Posted by a96bimmerm3
Have you done measurements on the cross setup for the R56? Seems as though you could adjust all that stuff to be the way you want, no?
No I haven't. You can't adjust actual damper stroke, that's fixed. If anyone out there that has Cross coilovers can use a tape measure, please measure total possible stroke [full compression to full droop]
Old Apr 8, 2009 | 07:14 PM
  #29
Bezlar's Avatar
Bezlar
The coilovers not the springs.
Barry
Old Apr 9, 2009 | 10:56 AM
  #30
a96bimmerm3's Avatar
a96bimmerm3
I really don't think they drop a full inch... my car still looks suvlike lol. Then again I have camber plates.
Old Apr 9, 2009 | 11:01 AM
  #31
BlackSapphire's Avatar
BlackSapphire
That is what I found on mine as well (when I had my TSWs).
Old Apr 9, 2009 | 01:40 PM
  #32
a96bimmerm3
How do you like your konis by comparison?
Old Apr 9, 2009 | 01:42 PM
  #33
BlackSapphire
I'm pretty sure you meant KW... the simple answer is "I love them". I feel like they are the best of both worlds.. looks and ride quality (based on the four suspensions I've had in my car to date). Their dampers are super high quality and should last longer than my ownership of the car. Plus, I can recoup some of the investment when it comes time to sell the car (I kept my OEM struts/springs).
Old Apr 9, 2009 | 03:45 PM
  #34
a96bimmerm3
Yeah, meant KWs. Been a long week. Sweet review. I think the TSWs are going to stay on my car- I can finally clear speedbumps without hurting my car. We'll see if they stay that long though.
Old Apr 10, 2009 | 02:40 PM
  #35
todoubled's Avatar
todoubled
im slightly confused i travel nyc streets and would like to lower my car but stock is killer around here in terms of comfort very harsh. im as intrested in lowering as comfort so what to do? so from what i understand the vmaxx or kws are my best option?
Old Apr 10, 2009 | 02:48 PM
  #36
BlackSapphire
First of all, nice MINI. Secondly, how low do you want to go? All suspension modifications are generally a trade off in one way or another. KW and Cross are the two main ones I'd consider as I don't know as much about the VMAXX ones. I went with KW because I have never heard much of a complaint from anyone and they were half the money of the Cross. Also, ask yourself if you really want 100 different settings to tweak or if you're looking for something that's turn-key with minimal setup (install, adjust height, and roll). If I had the money to burn, I would have dropped $2K on Cross. Then again, the tweaker in me would have been adjusting them every weekend.
Old May 28, 2009 | 10:33 AM
  #37
MoxieMini's Avatar
MoxieMini
Anyone know if there's any difference between the KW's for an R56 and R53 besides the rear bushings?
Old May 28, 2009 | 12:44 PM
  #38
Dizzee Rasca1's Avatar
Dizzee Rasca1
BlackSapphire: you have the KW V1's?
gknorr
Dec 26, 2016 09:38 AM
gar56
Nov 15, 2016 06:41 AM
Island maser
General Discussion
Oct 1, 2015 01:09 PM
Emnotek
Sep 29, 2015 07:37 AM
krohm
Sep 28, 2015 12:16 PM
