Suspension SPC/Eibach camber plates and KW V1's?
Old Feb 17, 2009 | 02:46 PM
BiZzLeSMiNI's Avatar
BiZzLeSMiNI
Hey all,
Just wondering if the SPC/Eibach plates can be run with the KW V1 coilovers. JSC speed says "Designed for use with the stock suspension or anything maintaining the stock mount and shock shaft diameter". I am pretty sure the V1's use the stock spring perch, can anyone verify that I can run these plates for sure with the KW V1's?
Thanks in advance!!
Old Feb 17, 2009 | 10:48 PM
Pharaoh's Avatar
Pharaoh
I'm sure you would have no problems with SPC plates. The KW V1 do not use stock spring perch however. The SPC will work fine with them or coilovers that use the stock spring perch so you should be good on what ever coilovers you have. A friend uses SPC plates on his car (non mini) and has had no problems. I however was not real impressed that I remember of the cost to quality ratio of the parts.
got_mini?
Oct 7, 2015 02:12 PM
Oct 1, 2015 12:34 PM
Oct 1, 2015 12:28 PM
Oct 1, 2015 12:13 PM
