Suspension OEM Control Arm Bushing Life
Old Jan 14, 2009 | 05:21 PM
  #51
onasled's Avatar
onasled
Haaa, Matt, ... it's not that easy. Have to remember that not so many people have the skill you have.
Unless Blazer is a real good wrencher then he may have to pay the price.
Old Jan 17, 2009 | 07:37 PM
  #52
JAB 67's Avatar
JAB 67
Depending on the age of your car, if you do it yourself you may want to do the ball joints at the same time as well.
Which ball joints? At the apex of the control arm, or at the strut? And, is it necessary to lower the subframe in order to r&r the apex ones?
Old Jan 17, 2009 | 09:20 PM
  #53
tazio's Avatar
tazio
Originally Posted by J A Blazer
Dealer quote me a price in excess of $1,000 for parts, labor, and alignment to replace the front end lower control arm bushings. I think that is obscene.
My guy did this job for $300 all up.
Old Jan 18, 2009 | 08:28 AM
  #54
Dr Obnxs's Avatar
Dr Obnxs
There are two ball joint on the front control arm...
one at the inner pivot, the other under the steering knuckle.
There are those that use a special tool to swap the front bushing, but if you do drop the front subframe, everything is there with easy access. There are other things to think about are steering rack bushing, as well as those for the front sway bar.
As far as the difficulty in the work, it's more effort than skill. It seems like a big job, but it's really more of a just "follow the steps" kind of work...
Matt
Old Jan 18, 2009 | 09:03 AM
  #55
jhiggs26's Avatar
jhiggs26
If you drop the front sub make sure your MINI is as high as possible for ease of re and re-ing! I'd jack up the back way up too and put her on 4 jack stand/blocks.
It's easy to check your ball joints during this job with a good wiggle test! Good luck!
Jeremy
Old Jan 19, 2009 | 08:09 AM
  #56
meb's Avatar
meb
...or, just remove both axles and the LCA inner ball joint is accessible.
Old Jan 19, 2009 | 09:11 AM
  #57
Dr Obnxs's Avatar
Dr Obnxs
One of the times I drop the front sub frame...
when I had 60-80 thousand miles on the car, I just replaced all the ball joints.... The parts are relatively cheap and when the sub is out it is an easy job.... Also, if your swapping them, you can go Godzilla on them to get them out without worrying about pinching the boots.....
Matt
Old Jan 20, 2009 | 05:45 AM
  #58
meb's Avatar
meb
5 lb sledge hammer = godzilla
Old Jan 20, 2009 | 04:57 PM
  #59
k-huevo's Avatar
k-huevo
Originally Posted by onasled
Is the outer ball joint ON the control ar then? Or like the R53, on the upright (hub)?
Here's a photo that may be of help.
Old Jan 21, 2009 | 05:04 AM
  #60
meb's Avatar
meb
Hey kieth,
I'm not familiar with the R56, but it looks like the lower, outer ball joint slides into the control arm and is held in place by 2-3 bolts...if so, a modified ball joint design would make a great camber adjuster...while also affecting track and a few other things...axle articulation...
Old Jan 21, 2009 | 05:27 AM
  #61
Carpe Diem's Avatar
Carpe Diem
It seems to be a relatively easy job to drop the subframe in ones driveway - has anyone tried to replace the stock Bushings with poly ones? What kind of headaches would this bring?
Old Jan 21, 2009 | 08:06 AM
  #62
IanF's Avatar
IanF
Search function thy friend be...
In a nutshell: Yes. Personally, many times (3 w/ 3-4 more pending). Headaches? Depends on who you ask. IMO, the biggest headache may be maintenance as you may need to clean and regrease depending on driving conditions, which requires some disassembly.
W0TM8
Dec 19, 2019 07:50 AM
Toolman
Jan 20, 2016 06:50 AM
maestro39
Oct 27, 2015 02:38 PM
JPMontes3
Aug 23, 2015 01:26 AM
Minibeagle
Aug 13, 2015 10:00 AM
