Suspension Rear Suspension Clunking
Old Sep 26, 2008 | 12:48 PM
ahendy's Avatar
ahendy
I just installed a 19 mm Alta rear sway bar and endlinks and have found that when going over bumps at a slow speed, there is a slight clunking coming from the rear suspension. I can't exactly pinpoint it, and it's not consistent with bumps, but it is definitely there, and I don't remember hearing it before the sway bar install
Any idea what this could be?
Thanks!
Old Sep 26, 2008 | 02:41 PM
th3118's Avatar
th3118
Coordinator :: Dynamic MiNi Collective
A common issue is the end links not being tight enough. Thats the bolt that goes though the end of the sway bar in the adjustment holes. They have to be really tight or they will clunk. Double check those first.
Old Sep 27, 2008 | 08:29 AM
ahendy's Avatar
ahendy
That makes sense. I'm out of town right now, but I'll check it out when I get home. Just for reference, the sound is a sort of "knocking" type sound from the rear. It seems like the endlinks could make that noise on the sway bar... lets hope it's that simple!
Ryephile
Suspension
113
Feb 9, 2020 03:43 PM
ebowling
90
Aug 4, 2019 09:15 AM
Minibeagle
Aug 13, 2015 10:00 AM
nomar116
Aug 10, 2015 11:24 PM
