Suspension :( pot hole... what did I break!?
Old Jul 2, 2008 | 07:29 PM
  #26
OldRick's Avatar
OldRick
If you drive around turns, you will LOVE the Star Specs. Stickiest summer street tire I've ever tried.
Old Jul 2, 2008 | 07:34 PM
  #27
TWON's Avatar
TWON
Well Rick,
I did buy a Mini, the funnest way to get from point A to point B is not a straight line.
Old Jul 2, 2008 | 09:41 PM
  #28
COR BLMY's Avatar
COR BLMY
just 3 turns ...I do not NOT suggest ....
Maybe it is the wheels ...
The stock lug bolt (I measured an '03 and a '05) is 30 mm from taper tp end.
If you only have 3 turns look at studs or longer nuts.
Mini Mania has a 35 mm Lug Bolt for under $3 each
Old Jul 2, 2008 | 09:45 PM
  #29
TWON's Avatar
TWON
Ahh great, lol
more money!
Old Jul 3, 2008 | 03:53 PM
  #30
TWON's Avatar
TWON
OK, add to the ever growing list... studs and another set of 5mm spacers on there way too now.
Old Jul 3, 2008 | 06:55 PM
  #31
oxtox's Avatar
oxtox
it will end.......er, pause you my friend will have one fine handlin' mini and that will make ya smile everyday....so it's all good!
Old Jul 5, 2008 | 08:47 PM
  #32
blackie's Avatar
blackie
Originally Posted by muladesigns1
you could return them for a defective replacement from where you bought them.
you shouldn't need tire insurance either. they will pro-rate the tire, but it still beats full price of a new ones.
info for next time?
Re: tire insurance
I have a cabrio, so runflats are the rule. Buying tire insurance was the best thing I could have done, at least for these original tires, as I have already damaged 3 of them (mostly from potholes; NJ and NY is full of them) in only 2 years of driving (2 had sidewall bulges and the third picked up a screw), so I basically spent on the tire insurance half of what the 3 runflat replacements cost. I think when the tire insurance lapses though and I wear down the runflats, I'm dumping them, even if it means carrying a spare in the back seat. To me the runflats are very unforgiving (in terms of the ride and are easily damaged, as a result) and the cost much more too.
Old Jul 6, 2008 | 09:13 AM
  #33
TWON's Avatar
TWON
You don't need a spare, just carry a plug kit, pliers and a small pump. You should probably carry a plug kit now anyways. Although you can make it home with the runflats, one of my flats, went completely flat and the <10 mile drive home nearly wore it bald, I should have just put a plug in it right away.
Old Jul 7, 2008 | 03:29 AM
  #34
blackie's Avatar
blackie
Damn! I drove like 70 miles on the one that picked up the screw and went flat and it still had plenty of tread. Of course, it probably had only 5,000 miles of wear on it before the screw,
Doc Pain
Mar 10, 2021 04:50 AM
vulkandino
Oct 31, 2015 08:29 PM
Doc Pain
Oct 28, 2015 07:09 PM
Nicefeet
Sep 27, 2015 11:14 AM
Engender
Sep 23, 2015 03:38 PM
