Suspension Advice...How to Adjust Coilovers?
Old Apr 25, 2008 | 07:18 AM
VJD's Avatar
VJD
As mentioned in my other post, last weekend I installed H&R Street Performance Coilovers on my R56. Question, with the rear spring perches set at the same height, the left rear corner of the car sits about a 1/2 inch lower than the right (passenger) side. This must be because of the gas tank? Since adjusting the perches up increases spring preload, should I increase the spring preload on the left or decrease on the right side to level out the car? Or just leave it alone? BTW, the front is level. Advice? Thanks.
Old Apr 27, 2008 | 07:17 PM
S-Driver's Avatar
S-Driver
I'm not familiar with your set up but can't you just adj ride height without messing with the spring perch adjustment? Isn't there a couple of other (lock/adj) nuts below that perch nut?
Old Apr 27, 2008 | 07:58 PM
ScottRiqui's Avatar
ScottRiqui
No, the H&R coilovers don't have a separate ride-height adjustment. Any adjustments to height have to be made by adjusting the preload.
The H&R coilovers don't have adjustable damping either.
Old Apr 28, 2008 | 06:05 AM
Bhatch's Avatar
Bhatch
the proper way is by corner weighting the car. and all 4 will be different when you finish.
Old Apr 28, 2008 | 07:46 AM
ScottRiqui's Avatar
ScottRiqui
Yes, but with some coilovers, you can corner-weight the car without having to mess with preload. I didn't have to touch the preload when I corner-weighted mine. I've never needed to adjust the preload for anything, actually.
Old May 2, 2008 | 02:00 PM
Auto_Pilot's Avatar
Auto_Pilot
I'd find a nice Race shop in the area...and have them do it, but show you how in the process.
Keet
Suspension
Aug 30, 2016 03:46 PM
CooperSharp
Oct 12, 2015 09:21 AM
vetsvette
Oct 11, 2015 06:05 PM
Suspension Products
Oct 1, 2015 11:53 AM
Suspension Products
Oct 1, 2015 11:14 AM
