Suspension TSW's New Camber Plates... get ready!
Old Sep 14, 2009 | 07:32 PM
  #76
JIMINNI's Avatar
JIMINNI
Originally Posted by Neufusion
Are these no longer for sale?
I checked the TSW site but couldn't find them...
Nope. Call them, they are developing new ones, but not sure they are out yet? I went with the Hotchkis as I needed them now
Old Sep 14, 2009 | 09:28 PM
  #77
O.C.abrio's Avatar
O.C.abrio
try www.vorshlag.com for these camber plates. there are several retailers to get these from.
i'm just about to order these. i have one mushroomed strut tower to get hammered back in place prior to install.
Old Sep 15, 2009 | 04:48 AM
  #78
onasled's Avatar
onasled
You can get these at TSW I believe. I just installed them in a customers car and I feel they are by far the best camber plates out there for the Mini. Really good stuff.
Old Sep 15, 2009 | 06:13 AM
  #79
DanF's Avatar
DanF
They are on the out motoring web site. I heard that for some reason TSW dropped them.
Old Sep 15, 2009 | 07:31 AM
  #80
JIMINNI's Avatar
JIMINNI
I originaly got the Vorshlags from Outmotoring but they seemed to be different than the TSW ones? Steve from CMS has put many TSW plates on and he said they were different. My M7 coilovers are not compatible at all with the Vorshlags. So we went with the Hotchkis, they have the upper and lower bearings too. Plus IMHO they are easier to adj. As they fit the hole perfectly.
Old Sep 16, 2009 | 09:37 AM
  #81
PenelopeG3's Avatar
PenelopeG3
Can you comment further on this?
How do you think they would work with Koni struts and OEM sport springs? TSW's earlier comments seem to say that you shouldn't use them with that shock, spring combo.
Old Sep 16, 2009 | 09:48 AM
  #82
onasled's Avatar
onasled
Well, ... I've worked with many different camber plates and by far these were the best "quality" and the best "thought out" Mini camber plates I've seen.
I can't comment of fitment to factory style barrel springs and shocks as I have not done so.
The guys at TSW know what they are talking about over there so I'd just contact them and see what they say. They have a lot more experience with different setups then I I'm sure.
I do believe that we got these plates from TSW along with the KW coilovers. I think they may have had to do some 'matching' in their shop.
I now run Ireland race plates in my racecar and if I can I will switch to these instead.
Old Sep 16, 2009 | 11:12 AM
  #83
JIMINNI's Avatar
JIMINNI
Another thing we noticed on the Vorshlags was that inner shoulder, were the strut seats up inside the plate, was cone shaped and the OEM strut shoulder is flat. Making it not the optimum seating surface. Remember I said OEM strut, not sure about other coilovers and struts.
Old Sep 22, 2009 | 08:51 PM
  #84
KC Jr 54's Avatar
KC Jr 54
The original plates was a partnership between Vorshlag and TSW, and until very recently TSW still highly recommended them. The two companies had a 'falling' out and thats why TSW doesnt carry them currently.
TSW is VERY very close to finishing their all new camber/caster plates. Last i heard, they were out to bidding for mass production. Call them, and speak directly to the horse itself though.
IMO The Vorshlag plates are extremely nice plates too. Was very impressed with the build quality and fitment.
JIMINNI: can you post a photo if you can of your Vorshlag plates?
Old Sep 24, 2009 | 02:43 PM
  #85
O.C.abrio's Avatar
O.C.abrio
pictures
here are mine...
Attached Thumbnails TSW's New Camber Plates... get ready!-dsc03444.jpg   TSW's New Camber Plates... get ready!-dsc03453.jpg   TSW's New Camber Plates... get ready!-dsc03470.jpg
Old Sep 24, 2009 | 05:29 PM
  #86
JIMINNI's Avatar
JIMINNI
I had to send the Vorshlags back as they were not compatible with my M7 coilovers. I went with the Hotchkis plates.
Old Sep 24, 2009 | 05:35 PM
  #87
JIMINNI's Avatar
JIMINNI
here are mine...
Yep those are the ones. If you look closely at your first picture, the one showing both plates, the plate on the left, the upside down one. The seat up inside is conical shaped, you can see it on the pic. The OEM strut has a flat surface that mates with that surface, not optimum. Now most people that use camber plates are not useing OEM struts so there is no problem then, as long has whatever you are using seats up good.
Old Sep 25, 2009 | 09:19 AM
  #88
PenelopeG3's Avatar
PenelopeG3
here are mine...
Are those installed correctly? How the heck do you make adjustments when half the adjustment bolts are covered by the sheet metal????
Old Sep 25, 2009 | 11:01 AM
  #89
O.C.abrio's Avatar
O.C.abrio
these are oriented correctly. there are markings which tell you which side faces "out" during installation.
No alignment has been done yet, but these seem set for max negative camber. I agree...the adjustment bolts are not assessible with a standard allen wrench at the current setting. One of my pictures shows an allen wrench in one adjustment bolt...and how I can't currently reach the other bolts. I'm no expert, but it looks like there is an alternative hole to move one adjustment bolt over for easier access. We'll see after the alignment next week.
I have seen this same adjustment issue with similar camber plates (Cross, Megan, etc.).
Old Sep 25, 2009 | 02:15 PM
  #90
PenelopeG3's Avatar
PenelopeG3
Thanks.
Apparently Vorshlag sells this tool to try and help the issue:
http://www.vorshlag.com/product_info...64000882e7415f
Old Sep 25, 2009 | 03:26 PM
  #91
JIMINNI's Avatar
JIMINNI
The people I know that use them end up cutting the hole bigger. That is one reason I really like my hotchkis plates. But the hotchkis plates will not work with struts that go all the way thru the camber plate.
Old Nov 8, 2009 | 12:31 PM
  #92
Longboard110's Avatar
Longboard110
availability of the TSW's?
Old Dec 29, 2009 | 01:56 PM
  #93
sranderle's Avatar
sranderle
Any news?
Keet
Suspension
Aug 30, 2016 03:46 PM
minieater
Oct 28, 2015 02:15 PM
fkrowland
Sep 30, 2015 10:30 AM
Keet
SCCA Solo and ProSolo
Sep 20, 2015 01:02 PM
Keet
Sep 19, 2015 09:45 PM
