Suspension could someone shed some light...
alignment- could someone shed some light...
...on my alignment. they (grismer tire) couldnt adjust the rear toe because they didnt have the proper tool to do so. so, with these numbers, should i go somewhere else and have the rear toe adjusted or will it be fine as it is?
-shawn
-shawn
You don't need a special tool....There is one, but I don't use it because it is a PITA. All you have to do is to loosen up the 3 16mm bolts and use a prybar to move the control arm....And yes, those toe numbers are extreme. You need to have it readjusted.
silence2-38554
Sep 24, 2015 05:34 AM
R50/53 EBC vs. Akebono - EBC wins
David.R53
Sep 13, 2015 03:44 PM
