Suspension M7 Strut Brace Hight Problem
I put some school chalk on the bar and closed the bonnet to see where the bar was hitting the pad. With a utility knife I scored along the chalk marks and by hand dug out only the amount of padding to clear the bar. Then sprayed the area of the removed padding with plain old black enamel paint. 2-3 coats (only in the channel left buy the removed padding), letting dry between coats. You have to look hard to see the channel in the padding. I've never had anyone notice unless I pointed to the channel.
More explanation please?
All you have to do then is use exacto and fingers to carve out insulation from the inside, and then replace liner with the fasteners.
This is the better method, in my opinion, because it keeps the liner looking OEM and keeps insulation from raining down on the engine bay if you've cut the front of the liner.
Hey ... "Sushi"
good to meet you today ...
Hope it was me that inspired the install ...
2 mm won't hurt ...but not the way it really should be.
If your that close (as I have seen some more than 5mm "lift")
I'll bet we could do a "soak the liner and squish" mod...
If you REALY soak the pad and then lay a couple of layers of cardboard or wood door trim or a yardstick right on top of the bar (not to much ...about 1/4 inch or less) take a deep breath and shut the bonnet (it needs to latch)
then go watch some racing on TV ... have dinner ... go to bed ...WAIT .. like overnight.
The open the bonnet, remove the "spacer material" and the padding will be crushed enough to clear the bar with a bit extra.
My bonnet which has been dented by the strut-brace actually allows more cooling air to reach the engine bay (jk!)
Or
On one hand, the strut brace may not allow my bonnet to close......but I'm saving wear and tear on the hood release.........
.......April Fools!
Some gullible person may actually believe this rubbish. You wouldn't want that - would you?
Keep smiling!
Skip
Do you have the CAD pic to show the extra cooling efficiency?
This is about the 4th time I have thrown this one out there and finally someone picked up on it . What took you guys so long to find it ?
Randy
M7 Tuning
You didn't go decaff did you ? They closed down all of the Starbucks for a few hours for training one day recently and most of Los Angeles went into shock .
Randy
M7 Tuning
Randy
M7 Tuning
hell no!
offtopic, but check out Nate's stuff - he's local to you - www.wcrcompany.com - the Torro is awesome for espresso, and the Colombian is better than any Starbucks I've had for a drip machine.
I've cut back to one cup/day instead of the normal 3-4
hell no!
As for back on topic it is good that this thread pops up now and then to see the various methods people have come up with solutions to the Bulge situation no matter what the brand. The soak and slam still seems to take care of most issues but the trimming of the liner from the back side looks like the best solution for those with more of an problem. Thanks to all who are participating
Randy
M7 Tuning
I think it is even more random that that. I have a 02 and I had three different bars with bulge " issues " . Go figure ?
Randy
M7 Tuning
i just recently installed my bar on an '03 and used the "soak and slam" method, still has a hood bulge so im gonna try removing the liner and trimming it, seems like that is the final cure.
