Suspension racing swaybars on a daily driver
goin with the H sport competition sway bar set, there adjustable and with lowering springs and camber plates it shoulld handle pretty well. does anyone know where to get the mounting U clamps and bushings for these bars? thanks
As the car turns right, the swaybar twists - in opposite directions. The left hand side twists clockwise or towards the front of the car(pulls up) and the right side twisits towards the back (pulls down). This exact motion, to my way of thinking, places each endlink in tension - one pulling up and the other pulling down.
the gti had NO endlinks. it had a swaybar bolted directly to the rear twist beam axle (VW guys correct me it i am wrong). at least in my scirocco it was this way. the twist beam axle acted much like a huge swaybar with wheels attached to it. VW simply bolted the swaybar to the axle; it became a part of the assembly and increased the torsional rigidity of the whole axle. completely different system.
as far as a change in performance from endlinks, that is practically impossible. the only way you could gain any benefit is if your old ones were stretching or buckling under load. endlinks to not change the stiffness of the swaybar in anyway, they mearly transfer the forces from the bar to the suspension arm.
Last edited by sonichris; Jan 29, 2008 at 08:01 PM. Reason: fixed quotes. it's /, NOT \... friggin forwardslash...
Re the VW...yes, you are correct as I owned a couple. not sure why Chip said this about wheels lifting; there are plenty of front and rear wheel driven race vehicles with a little air under either the inside rear or inside front.
So, did I explain myself correctly? Not sure I get that impression from your first quoted reply sonichris...as the car leans, the inside wheel extends pulling down the sway bar on that side causing the other side to pull up. If the leaning side in my orientation above caused that endlink to compress, it would also cause the other side to compress. The very origin of the operation is in question and determines eith tension or compression, not both...and not compression in my brain...but I'm old.
And yes, I agree if I wasn't clear here. Once the rear wheel leaves the ground the sway bar will contribute nothing more, meaning exactly that it has contributed all it can, not that it is off line. My poor choice of words...but I more than likely wrote this somehwere else with a little more clarity.
I still do not see how there is any compressive force in a sway bar endlink - re your chain analogy? If one side pulls up, the other must pull down. I understand your reply and its a great question. I don't have an answer...except that stock cars go in a circle and a chain will remove anychance of bind until it is needed???
If I were to merely thin slice this I would focus on the design and delicate nature of endlinks...these cannot absorbe compressive loads without deflecting or failing. They simply are not that strong.
The change in performance was the difference between heim joints and ball joints. A hiem joint has about half the articulating range a ball joint has.
another illustration; If I pull down on one side of the sway bar via an endlink, the other side of the sway bar pulls up.
how about this... disconnect one endlink at the control arm and pull down. now analize the force on the other link... it is resisting the movement of the swaybar by... compressive force. it is acting UP on the bar resisting the DOWN force on the other side. equal and opposite.
Am I thick headed? I must like punishment...
Chris, Jasen,
My last statement suggests, in spirit, what you are asking me to try - they are one and the same. Except, I agree your results and not mine...foolish! The results will be as you state. However, and refer to thick headed above, are you suggesting that all of the twisting and weight transfer is funneled thru that tiny endlink on the outside rear wheel?
If you were to draw with arrows, beginning at X (X being the beginning of the path of weight transfer) where would your string of arrows begin and end - including rotation in the bar?
...and still, i'm not sure i believe the contribution when the wheel is off the ground...at that point the compressed side has all of the bar rate plus spring rate and the opposite side is at full droop or nearly so since the bar is working just a little to compress things. Sp where's the twist...beef? I don't do this for a living and so you guys are asking me to sort of second guess myself...
Chris, Jasen,
In the rear, a stiffer bar will, wether it be thicker or on a stiffer setting either way. In autocross, sometimes people in gstock (where you are not allowed to change the rear bar) will swap the cooper s front bar for a cooper bar, which is less stiff in order to reduce understeer.
our front bars are alot bigger than the rear from the factory. its like 25mm front and 17mm rear from the factory.
so you see, those little skinny endlinks don't have a whole lot of force acting through them. the springs actually do most of it. that's why they can be so skinny and still be ok. now, if you put a massive swaybar on there, the force transmitted through the endlinks goes up. that's usually when you see these things buckle or snap - when you increase the swaybar diameter.
no. could you still have understeer? yeah, sure in some cases, but will it be enough to be a problem? no. I dont want to get to many different topics going here, if you want more info, PM me, and iwill try to explain it in more detail.
actually sorry man, i didnt realize you were the OP. This thread got way off topic on you, tomorrow night i will try to PM you about sway bars. I was going to go your route, then changed my mind. Dont really have time right now to go in depth, but i will try in the next day or two get back to you with some info about the pros and cons of big bars.
Jasonmf,
Perhaps I am wrong...but I am repeating what I've been taught and what I've been told. And, to the benefit of all contributing, this is a fairly complicated operation. I too am contributing repsectively...and learning as we all continue to do. So I appreciate your challenge because it causes me to dig a little deeper.
Here's my picture or orientation; I am facing the back of the car, the car turns right and leans to the left.
What follows is my view of the operation of the swaybar.
same situation, RH turn:
The body of the car naturally tries to roll to the left, forcing the suspension into compression (up into the wheel well) on the LH side. As the suspension travels UP (in relation to the body), it pushes the endlink UP with it. This push up on the endlink is what puts the outside endlink into compression. This compressive force on the endlink (pushing UP) is now trying to rotate the swaybar up in it's bushings.
Now lets look at the RH (inside of the car):
As the car rolls to the left, the suspension on the RH side tries to droop down. This downward droop (being pushed down by the force of the spring) now pulls down against the endlink, trying to pull (tension) against the swaybar, which tries to rotate it down.
The swaybar sees the outside trying to push it up, and the inside trying to pull it down. This is the torsion.
I cannot describe in physical terms my thoughts about the swaybar's effectiveness as one tire leaves the ground...but I have been told by more than one engineer that this is so. My own logic tells me that this must be so but I am honestly at a loss to describe this condition elegantly. So I'll hold off until I receive more info which clarifies my above statements. I want my thoughts, and the help I receive to be clear so I can help us all. The possibility exists that I might the only one who is indeed lost...
The swaybar adds to roll stiffness due to the fact that it is linking both springs together, an infinitely stiff swaybar would double the spring rate because the suspension now has to compress BOTH rear springs.
Once the inside tire is off the ground, any further lateral acceleration is going to try to roll the vehicle more which is going to try to compress BOTH springs more due to the swaybar. Lets say for the sake of argument, the tire lifts at .8 g's but the car is still capable of pulling 1.0 g's. The lateral acceleration between .8 and 1.0 g's is causing more roll of the car, and that extra roll is still asking the swaybar to do work.
In truth, you have to wonder, given the delicate nature of endlinks, how these can possibly work in compression...even if the do not snap, the deflection produced in compression would render these somewhat ineffective...and I assert, make the swaybar work asymetrically; if one side is in complete tension while the other is in compression and deflecting - its length has therefore changed - a swaybar cannot work symetrically in this environment. Yes, I know there are circumstances where a bar is designed to work asymterically, but that discussion is beyond me and will only confuse this discussion.
EDIT
Dare I write, jasenmf, that the action of the endlink/swaybar on the rear compressing side is resisting the compressive forces...in fact countering the compression in tha spring and damper. (???) If this di not occur, the weight could not be transfered to the inside front wheel ???
In fact, many stock cars do not use an endlink on one side and use a chain on the other, yes, a chain. A chain can only work in tension. The other end is left loose and the twist begins when the untehtered end comes into contact with the control arm.
I also spoke with Chip Minik, owner and engineer for Powergrid endlinks. Chips' response to a lifting wheel si that there is "no more contribution to weight transfer" But, he went on to say that any front wheel drive car whos inside wheel leifts off the ground is the result of a poor endlink design - the endlink is in bind. He also pointed to a number of every day regualr cars - old GTI - that exhibit this trait.
I can offer this, once I installed Chip's endlinks, my mini's inside rear wheel never left the ground...not rreally sure about this one though...
This isn't punishment, this is fun stuff!
Chris, Jasen,
The swaybar and opposite spring are acting as two springs in series they can be treated as ONE spring with an effective spring rate somewhere less than either by itself
This ONE effective spring is working with the spring already on the outside, so the outside suspension effectively now has TWO springs making it stiffer than if it did not have the swaybar at all.
... so, increasing the spring rate would make the car lean less in the turns (can we agree on this?). since the car is leaning less in the turns, the swaybar is twisting less, and thus transmitting less force on the endlinks.
Now, let me see how many typos I can find once I hit "send"
Jason
The lower the speeds, the greater the tendency for the car to understeer. If you are setup for autocrossing where the speeds are relatively slow, the big front bar might be a bad thing. If you are setup for a open track where you are talking higher speeds, the autocross setup might make the car way too oversteer prone and the big front bar might help.
Jason
Well, one thing is true, I am thick headed...there is a term in Italian...but we'll leave it off the table for now. I sincerely appreciate your efforts, Chris and Jasen, to remain calm while I throw some really odd ball stuff back at you guys. And my apologies to the OP!!! But hope he is enjoying the ride??? Er, she?
First...Chris...brain block about pulling down on the link. Got it! I dunno where that came from
...read on...
Simpler stuff first...heavier springs = less contribution from the swaybar. The message here is light springs will allow more twist - not new news to many of us. What's interesting here is that as dampers become more capable of handling higher and higher spring rates, sway bars become the high fidelity - to an even higher degree - components in the suspension make up - relative to race setups.
The fundamental problem with my entire view was the direction of twist; my view is opposite reality and this essentially corrects most of my thinking.
The contribution the sway bar adds to rate is a tricky one yes? Among the variables, rising rate suspension, motion ratio and perhaps a few other elements? But, 1,600lbs of compressive force? I suspect that is ideally thru the center of the endlink??? But here I see a problem...adjustable sway bars often use one static location while the other is adjustable. to my way of thinking this places some very un-natural loads on an endlink out of vertical load - pure vertical load???
And finally, the lifting tire again - sorry
. Jasen, would your argument be true if the car could manage to increase lateral grip from .8g to 1g? I know, I simply re-asked a sentence you wrote above, but how do we manage this on three wheels? I guess my assumptions were that cornering power drops off as the inside tire leaves the ground bringing an end to additional cornering power. I suppose it is vehicle or setup specific? I used the lifting wheel as my cue to set the limit of my swaybar settings. My thinking was that I would not gain any additional cornering power - or control/balance - but would have reached a sweet spot where an optimized amount of weight transfered to the inside front tire helping my front driver place power down more effectively???
You guys are my new heros
Listen, I contribute a lot here, but I am far from an expert. For the most part I have wisdom, not knowledge to share. Wisdom is knowledge gained from making lots of mistakes. As a child, I could not understand how all that lava traveled thru so much water to get to the top of a volcano. When I got it, I decided to become a landscape architect...about a decade and a half later...not really, but it's amusing!
To the OP, hope you are okay with all of this wonderful information. Someone had to ask the stupid question...actually, one of my statements was corrected...okay two or three.
...read on...Simpler stuff first...heavier springs = less contribution from the swaybar. The message here is light springs will allow more twist - not new news to many of us. What's interesting here is that as dampers become more capable of handling higher and higher spring rates, sway bars become the high fidelity - to an even higher degree - components in the suspension make up - relative to race setups.
. Jasen, would your argument be true if the car could manage to increase lateral grip from .8g to 1g? I know, I simply re-asked a sentence you wrote above, but how do we manage this on three wheels? I guess my assumptions were that cornering power drops off as the inside tire leaves the ground bringing an end to additional cornering power. I suppose it is vehicle or setup specific? I used the lifting wheel as my cue to set the limit of my swaybar settings. My thinking was that I would not gain any additional cornering power - or control/balance - but would have reached a sweet spot where an optimized amount of weight transfered to the inside front tire helping my front driver place power down more effectively???You guys are my new heros
But that's just a guess from a n00B.
i don't even know anymore. sorry for riding the tangent mobile on this one, but i love a spirited discussion!
P.S. i can't spell either, but i have a secret weapon--->
Okay, from Doug Milliken himself.
Michael,
Ha! You found our "Achilles' heel"--sometime after the book was done we realized that we didn't include any pictures of an anti-roll bar.
The revision/update process from one printing to the next (currently 10th printing) only allows us to make small changes in the text that stay on one page, so we have not been able to fix this.
Wikipedia has a nice article, the version I just read didn't have any glaring mistakes (but of course it can change at a moment's notice.
http://en.wikipedia.org/wiki/Sway_bar
When cornering with a typical installation, one link is in tension, the other in compression. Adding an anti roll bar increases the roll stiffness (roll rate) of the suspension, typical units are foot-pounds per degree of body roll angle.
Always happy to hear from someone who is using our books,
Doug Milliken
www.millikenresearch.com
I think Chip did much more to cloud my thinking than he did to clear anything up...
Michael,
Doug Milliken
Gatcha, but - and cornering is never as elegant as we think it is, if lateral Gs (drop off) or remain constant, how will the bar 'add' more contribution?
A guess from a noob...we're all new at something, welcome! You're just new here.
I'd expect that the inside spring is still going to exert more force as it continues to be compressed by the sway bar. Thus, even once the inside wheel is lifted, you could get more torque all the way to the end of the travel of the inside spring.
The sway bar's response isn't just a function of lateral G's. It's a function of the number of degrees of body roll. Imagine holding the car in a tight circle, perpetually holding a particular G force and the inside tire is just off the ground. Now suppose that some magical force comes along and tries to add more body roll, without any lateral G's. Assuming the springs haven't bottomed out, the sway bar should provide more force resisting the rotation.
Understood. But in steady state there are no changes in roll angle or g load and maybe thats where I'm off. I know this is not real life, but some isolated ideal is always a good beginning.
This is like reading a book by Emanual Kant; you have to keep a finger on every thought to make the connection and I've unfortunately run out of fingers
...I step back when I should look close and look close when I should step back...kinda like getting lost in a setup.
jetmechinnc
Nov 16, 2020 06:38 AM
