Suspension From where ?
Old Jan 10, 2008 | 10:59 AM
Luys's Avatar
Luys
From where ?
Hi, I have JCW R53 brake and i want to change the rotor.
- From where i can buy drilled or slotted or drilled and slotted rotors ? that fit JCW brake kit.
- Dose i will fell difference between JCW stock rotor and drilled or slotted ?
Thanks.
Old Jan 14, 2008 | 06:24 PM
CoolJamJar's Avatar
CoolJamJar
You can try here:
http://www.trademotion.com/partlocat...catalogid=4413
Old Jan 15, 2008 | 01:28 PM
rattmobbins's Avatar
rattmobbins
You'll get more responses in the 1st gen forum...
Old Jan 15, 2008 | 02:19 PM
scott48's Avatar
scott48
You can buy the JCW drilled/slotted rotors...that's what I have.
Old Jan 16, 2008 | 01:30 PM
DrosS's Avatar
DrosS
I would stick with slotted rotars. I have had drilled/slotted rotors before and they can get heat spots from high speed braking (I go to the track alot). The fact of the matter is that you lose surface area on the rotor when you have both...especually on a rotor that is only 294mm in diameter. I would trust any JCW product, though.
rattmobbins is right. You will most likely get more responses on the correct forum (1st gen).
