Suspension H & R spring issues
Old Oct 3, 2007 | 04:59 AM
-Vampyre-'s Avatar
-Vampyre-
H & R spring issues
I just istalled my new springs. Everything looks tight, but i get some rattle type noise when I go over bumps. I can also make the noise if I turn the steering wheel back and forth while driving. I will take it apart later today to check, but does anyone have any ideas of where I should look first?
Old Oct 3, 2007 | 06:23 AM
th3118's Avatar
th3118
Coordinator :: Dynamic MiNi Collective
Check your end links. They are known to make some noise if they are not super tight. Both front and rear.
Old Oct 3, 2007 | 06:33 AM
-Vampyre-'s Avatar
-Vampyre-
That is what i was thinking. I believe it is the only part of the spring install that could really be affected by the turning. I am going to take a long lunch today and pop off the front wheels to check. The noise is definately from the front, so I think the back are ok.
Old Oct 3, 2007 | 10:25 AM
-Vampyre-'s Avatar
-Vampyre-
Went home for lunch, pulled off the 2 front wheels and tightended the endlinks.....no more noise...thanx
Old Oct 3, 2007 | 10:58 AM
Bhatch's Avatar
Bhatch
I wish i could go home for lunch and still have time to work on my car :P
Old Oct 3, 2007 | 12:22 PM
-Vampyre-'s Avatar
-Vampyre-
I just moved last weekend. I get an hour for lunch, but sometimes i can be over. pretty easy going here, and i live 1.5 mi from work. Had time to change twice and clean up.
Old Oct 3, 2007 | 01:02 PM
edubledie's Avatar
edubledie
MUST BE NICE ....but then again i get to surf the net all day at work and still make bank
Old Oct 3, 2007 | 04:24 PM
rattmobbins's Avatar
rattmobbins
+1
Old Oct 4, 2007 | 08:03 AM
-Vampyre-'s Avatar
-Vampyre-
So do I. I do System Administration for a software developement company...so nani nani boo boo....lol
Old Oct 6, 2007 | 02:29 PM
Dave@ddmworks's Avatar
Dave@ddmworks
Manufacturer
Yeah, but we get to test cars all day, it was a fun week
By the way what do you think of the H&R's on the R56?
Old Oct 6, 2007 | 08:01 PM
-Vampyre-'s Avatar
-Vampyre-
I love em. it looks awesome. Should have been that way from the factory. Next on list is intake. Have to figure which one I want.
Old Oct 6, 2007 | 08:31 PM
rattmobbins
Pics???
I love me some dropped MINIs!!!
Old Oct 7, 2007 | 08:40 AM
SlowB00st's Avatar
SlowB00st
Huuuuum... ... I'll take the top one!!!
Old Oct 8, 2007 | 04:40 PM
ADAMSALTAMINI's Avatar
ADAMSALTAMINI
Some photos of my car on H&R's are HERE!
More to come with the new wheels as well! H&R rules!
OP: Sorry you had any difficulty with the installation. In the future, feel free to call or PM me with any questions or concerns!
Old Oct 9, 2007 | 07:19 AM
-Vampyre-'s Avatar
-Vampyre-
Wasn't really dificulty, just had to do the rears twice because i was in a hurry and forgot a part that looked like a socket on the ground. Then i just didn't tighten the front endlinks enough. Even with all that, I only spent about 4 hours time on it. Was pretty easy with your how to
Old Oct 11, 2007 | 08:02 AM
ALTAPerformance's Avatar
ALTAPerformance
Kool! 4-hours for your first time is very reasonable. Glad everything was resolved and the instructions helped!
Thanks again for your business!
Adam@altaminiperformance.com
Old Oct 27, 2007 | 08:21 AM
prb44t's Avatar
prb44t
I had H&R springs installed on my r56 a few weeks back. On hard throttle acceleration I get this pulsing feeling from the front of the car. It almost feels like the front tires are flat-spotted. I don't notice it unless its from a low speed acceleration with a good amount of throttle. I don't hear any clunking or any other sounds. Any one have any ideas?
Old Oct 27, 2007 | 08:24 AM
r56mini's Avatar
r56mini
Something rubbing somewhere? Like a tire?
Old Oct 27, 2007 | 08:35 AM
prb44t's Avatar
prb44t
stock 17" tires and rims. Don't remember hearing anyone else saying that had a clearance issue. When I say they feel like the tires are flat spotted, I mean the car kind of pulses. I haven't noticed any cupping of the tire when I run my hand over it.
Old Oct 29, 2007 | 07:23 AM
ALTAPerformance
That is VERY odd. Could be a couple things. First be sure that everything is tight and in the correct order. That noise MAY be a result of the upper front strut assembly not being re-installed properly. There is a washer etc. that has to be installed in a particular way. If not it can cause noise, damage etc. There is NO reason the car should have any pulsations after the installation. Good luck and keep us all posted! adam@altaminiperformance.com
Old Oct 29, 2007 | 09:19 AM
PaulCIssa's Avatar
PaulCIssa
I have the same condition after installing Mach V's 2 weeks back. It's a low-speed, rotational vibration that is more pronounced as more torque is applied. I get it through the driven shaft on the right (no LSD). Seems to come and go depending on the conditions; EI:uphill start/wheels turned or straight, etc.
I haven't had the alignment done yet, I'm curious if your's has. Could be toe adjustment, but my seat-of-the-pants diagnosis is CV joint alignment. I'm giving it a few more weeks before it goes on the rack to check alignment.
Old Oct 29, 2007 | 09:38 AM
ALTAPerformance
That is VERY odd. I have a hard time signing up that it is related to the CV angles. Keep us posted! Adam@altaminiperformance.com
Old Oct 29, 2007 | 10:10 AM
PaulCIssa's Avatar
PaulCIssa
I hope you're right 'cause I really want to agree with you! I mean, what are we talking about? Fractional degrees? Even at whole degrees, the spec range of sweep is far beyond whatever was introduced by the change in ride-height. Does that make sense? I hope it's just toe.
I just realized that I was high-jacking Vampyres thread. I'll start one on my subject. Sorry!
Old Oct 29, 2007 | 10:18 AM
ALTAPerformance
I think it makes more sense that it is assembly. Many people dont' keep track of the parts when they remove them. As a result they put the collar washers on upside down in the front. Thus causing the grinding. Needs to be corrected though ASAP! Adam
Old Oct 30, 2007 | 05:53 AM
ToMiTa's Avatar
ToMiTa
I just had H & R's installed yesterday on my R56. No problems at all except that I can visibly see slight negative camber on the 2 back wheels. In about a week, I will get an alignment.
