Suspension Sway bar differences, not just size...
Old Oct 3, 2007 | 09:32 AM
  #26
meb's Avatar
meb
Yes, yes!!!
Originally Posted by Turn In Concepts
PROVIDED!!! You are installing the endlinks with the car loaded on the suspension on level ground.
Old Oct 3, 2007 | 10:12 AM
  #27
Bhatch's Avatar
Bhatch
Originally Posted by meb
However, most adjustable endlinks are a little different, and a little stronger than stock. So in an effort to keep load transfer thru these equal side to side, buy in pairs.
to get your cross weights correct you need the car loaded with the driver and the sway bars disconnected.
on a side note, some sway bars have different heat treatments and differnt alloys. A larger diameter soild standard steel bar may not be stiffer then a smaller hollow stiffer alloy with different treatment bar.
Old Oct 3, 2007 | 10:35 AM
  #28
Mach V Dan's Avatar
Mach V Dan
While in theory what you're saying is possible, in practice you'll never find a hollow bar that's smaller than a solid one. The smallest hollow bars I've seen are always larger than (or at least equal to) the largest solid bars.
--Dan
Mach V
FastMINI.net
Mini7
Feb 2, 2016 07:52 PM
minimofo
Sep 9, 2015 10:29 AM
Bea5tMa5ter
Aug 27, 2015 01:42 PM
ClayTaylorNC
Aug 10, 2015 09:19 PM
OutMotoring
Aug 6, 2015 09:32 AM
