Suspension 19mm Swaybar - What, Where, Who?
Old Dec 7, 2007 | 05:41 AM
  #51
jascooper's Avatar
jascooper
Originally Posted by stevecooper
I heard about the alta sway squeeking, so I'm gonna make sure it doesnt squeek, by greasing the hell out of it before it goes on. Its gonna be our little project together when his car get's here.
Try wrapping it with plumbers teflon tape before inserting it through the car. Once it's in place, it's almost impossible to wrap well. You might even try putting the bushings on first too, but it might be a little tight getting them through the opening.
Old Dec 10, 2007 | 03:44 PM
  #52
ghosthound's Avatar
ghosthound
so the 19 mm H&R bar sounds like the way to go, Ive never done any suspension work and it sounds like if i want to eventually lower the car, id have to get the adjustable endlinks? also, this will be ok on the non sport suspension on the r56 S correct?
one last question... will the 19mm really be a noticeable difference? i dont want to have to sell it and buy a thicker bar because it only marginally increased the handling characteristics.
Old Dec 10, 2007 | 03:54 PM
  #53
r56mini's Avatar
r56mini
Dude, I have Alta 19mm bar. I am assuming the hole positions are similar for both brands. Mine is on the middle setting and it got rid of all the understeering. I am afraid the rear end might swing out if I put it all the way to the stiffiest setting but then there are people using 22mm bars at the stiffiest setting. For my driving style, I can appreciate the 19 mm bar in the middle setting plenty. Brake and turn.
When I first got the car and took the corners the front tires squealed a lot even with proper weight transition to the front before turning. But after getting the 19mm bar, the front tires some times go "chirp... chirp" and the car just turns. No more of the squealing pig noise is heard.
Mine doesn't have sport suspension.
Old Dec 14, 2007 | 04:39 AM
  #54
jascooper's Avatar
jascooper
Why do you think you need adjustable endlinks? They would make minimal difference in the torsion of the bar. If you're lowering the car, you might consider adjustable control arms to bring camber back toward desired specs.
I also have the Alta 19mm bar set on the middle setting. That yields just under 50% more stiffness than the stock bar. The tightest setting is about 80% stiffer, IIRC. I live in PA, and on a snowy road too much swaybar is probably a recipe for disaster.
I know the Alta bar has 3 positions for adjustment, and if I'm not mistaken, the H&R I saw only had two choices.
Old Dec 19, 2007 | 01:28 PM
  #55
jcap287's Avatar
jcap287
School away from MINI
So I think I'm gonna go with the H&R how would I determine which setting is which? Obivously the one closest to the bar is the stiffest. Would the first one be equal to alta and h-sports middle hole?
MrBlah
SCCA Solo and ProSolo
Feb 1, 2020 07:43 PM
richardsperry
Jul 30, 2018 04:48 PM
gar56
Nov 15, 2016 06:41 AM
vulkandino
Oct 31, 2015 08:29 PM
gnhovis
Sep 28, 2015 06:28 AM
