Suspension question on m7 srp
Old Aug 8, 2007 | 07:33 AM
edubledie's Avatar
edubledie
question on m7 srp
this may sound silly but if i take the nut off the struts bolt to place the SRP's on ....will the bolt fall through ? is the bolt welded to the strut ? im trying to determin if i will need to take my wheels and wheel wells off to do this install....help is appreciated.
Old Aug 8, 2007 | 07:54 AM
ScottinBend's Avatar
ScottinBend
If you have the stock strut plate, then all will be good.
Old Aug 8, 2007 | 08:05 AM
edubledie's Avatar
edubledie
hey thanks for the response....i dont quite understand though i have everything stock so the bolt doesnt needs to be held underneath with a wrench while i tighten the nut on top does it ? does this stock strut plate hold those bolts through the holes as i take the nuts off ...im worried that the botl will fall to the ground or in my car somewhere if i take the nut off
Old Aug 8, 2007 | 08:21 AM
Big Daddy's Avatar
Big Daddy
You needn't worry. The bolts are welded to the stock plate and will not move. Just loosen off the nuts, drop on the SRP's and torque them back down.
Old Aug 8, 2007 | 08:25 AM
edubledie's Avatar
edubledie
awesome...thank you VERYYYYY much for the help
Grizld700
Dec 30, 2015 10:47 AM
donniedarko
Oct 21, 2015 01:15 PM
twriter
Oct 2, 2015 03:14 PM
Carwash
Sep 15, 2015 02:02 AM
marc0011
Sep 10, 2015 10:04 PM
