Suspension Best Camber plates for Koni Yellows?
Old May 14, 2007 | 06:46 PM
Darkness's Avatar
Darkness
I recently installed Koni yellow and Hsport springs and need some camber plates. Which should I get so I can still adjust the Konis? I was going to get some Hsports but realized that the plate blocks the adjustment thing. the only option i've seen are the irelands. Are there any other options to look at?
I did a search but didn't find what I needed.
Old May 14, 2007 | 07:39 PM
hornguys's Avatar
hornguys
Hmm, are you SURE the H-Sports don't work with KONI Yellows?
I've had Koni Yellows on two different MCS's, and both with Helix/RDR plates.
Worked perfectly.
I thought H-Sport awas a lot like the Helix, only you lose the 1/2" height disadvantage of the Helix/RDR.
Old May 14, 2007 | 08:08 PM
Darkness's Avatar
Darkness
What i'm concerned about is the ability to still adjust the Koni's for autoX.
The blue plate on the top of the Hsports appears to block the adjuster on the front struts. If it does not block the adjuster then I am set on them. Way told me that you can't and that the Irelands were the best option.
The helix's are pretty much identical to the Hsports; do you have a picture of the adjuster on the Koni's with the helix plates so I can see if it would still be accessible to adjust with the **** that Koni gives with the struts?
Old May 14, 2007 | 09:26 PM
hornguys's Avatar
hornguys
No picture.
But I've been adjusting the Konis at track days and autox's for over TWO YEARS.
Works perfectly, UNLESS you dial in too much negative camber - say over -2.5 degrees.
Check with the guys at Helix - they'll tell you straight.
I'm still surprised that the H-Sports wouldn't work as well. Guess I never really looked at them close enough.
Old May 15, 2007 | 12:50 AM
AZMCS's Avatar
AZMCS
You still have a pretty tall stack with the H-Sports. I have installed both and they are almost an identical height. And design for that matter.
Old May 15, 2007 | 12:54 AM
OasisT's Avatar
OasisT
I simply drilled a hole out on the blue plate. That allows for very easy adjustment
Old May 15, 2007 | 05:12 AM
Darkness's Avatar
Darkness
Awesome, thanks for the help everyone!
All my questions are answered. I'll call helix up and see what they say, or just drill a hole (i like drills)
smdmini
Oct 7, 2019 06:05 AM
richardsperry
Jul 30, 2018 04:48 PM
conky
Apr 6, 2016 08:03 PM
Keet
SCCA Solo and ProSolo
Sep 20, 2015 01:02 PM
Keet
Sep 19, 2015 09:45 PM
