Powerflex Control Arm Bushing Feedback
Old Mar 15, 2012 | 07:32 PM
  #26
boxer's Avatar
boxer
+1 to Way and to PF. Thanks
Old Mar 19, 2012 | 04:32 AM
  #27
jhowla's Avatar
jhowla
NVH experience
Dielectric- I bought (from WMW) and installed the PF FCAB bushings and lower motor mount bushings a couple months ago. When I bought them, Way advised me to only install the larger yellow inserts in the lower mount to minimize NVH. I did not listen. I figured I paid for two bushings I'm going to install two bushings!! After the install I had some significant NVH in the cabin. There was some break in and after a month there was much less NVH. However, the wife still complained, so I put the smaller stock bushing back in the lower mount. Much better. Wish I had gone this route in the first place.
Old Mar 19, 2012 | 05:20 AM
  #28
bmwr606's Avatar
bmwr606
i have used Powerflex before in VWs
will they be available for my 2012 Countryman S ALL4?
scott
Old Mar 19, 2012 | 11:29 AM
  #29
laforze's Avatar
laforze
Looks like i know one of my next mods!
Old Mar 19, 2012 | 01:18 PM
  #30
bimmerwork's Avatar
bimmerwork
has anyone replaced the front lower control arm rear bushings (brake reaction bushings) themselves ? and is the special tool to pull the control arms out of the old bushings really necessary ? i already have the special tool to press out the old bushings from the brackets without removing the brackets from the chassis... and without dropping the subframe, which i do not want to do.
thanks in advance for any info that may help,
bimmerwork
Old Aug 30, 2012 | 07:00 AM
  #31
mrluckey's Avatar
mrluckey
Hello Rescay.
I need to purchase Power Flex front control arm bushings locally. Did you find them here in the Sacramento Valley?
Old Aug 30, 2012 | 07:53 AM
  #32
WayMotorWorks's Avatar
WayMotorWorks
Vendor
Originally Posted by mrluckey
Hello Rescay.
We can ship them to you no problem
http://www.waymotorworks.com/powerfl...shing-kit.html
Old Aug 30, 2012 | 11:11 AM
  #33
rescay's Avatar
rescay
I bought them from Way Motor Works.
Old Jan 31, 2013 | 12:00 PM
  #34
bobtop36's Avatar
bobtop36
I have been driving R53 minis for 10 years now.
2003 MCS installed Way prepressed LCA PF bushings at 130K car has 163K now, great improvement. My son has this car now and has been driving hard since it had 50K.
2005 MCS installed Way prepressed LCA PF bushings at 80K never had a problem or sqeek. Totaled the car at 146K collision with a wild hog.
2006 MCS installed Way prepressed LCA PF bushings at 67K car has 70k now and zero problems with the bushings on any of these cars.
I believe that this is a must install once your stock ones go bad. I can't recommend these strongly enough.
Old May 7, 2013 | 07:48 AM
  #35
GP0256's Avatar
GP0256
300 miles, 106k on the car, dramatic improvement over the stockers that held in for 8 years, hard to believe. The steering response is awesome, more direct and better feel. The whole car seems more solid. I wish mini would contract with power flex to put them in all MINI's from the factory.
Old Aug 27, 2013 | 08:15 PM
  #36
WayMotorWorks
Vendor
Would love to see more posts from users as we know this is the number one replacement for control arm bushings.
Old Aug 27, 2013 | 10:07 PM
  #37
xsmini's Avatar
xsmini
Did mine about 100k ago, love em!
Nik
Old Aug 28, 2013 | 06:21 AM
  #38
v10climber's Avatar
v10climber
Installed the PF bushings into our 2010 fJCW at probably around 10k miles. Car has 35k miles on it now. The bushings are awesome and are a great mod. When we pulled the subframe for the differential install I noticed the bushing were cracking on both sides. It doesn't seem to have affected the function of the bushing but I'm sure it'll get worse. Not sure if it was an installation problem (dealer did it since they were in there for warranty work) or what. I do know that Powerflex has an excellent warranty (just had a set of PF bushings warrantied on the STI). Eventually when I get around to it I'll send some pictures to PF and have them send me some new bushing that I can put in. Although I've been eyeing the SuperPro bushings...
Old Aug 28, 2013 | 07:52 AM
  #39
Herleman's Avatar
Herleman
Well, it is the number one replacement ---- does anybody actually use anything else?
The real issue for us is that you just don't know the original bushings are worn out till you notice that the front tires are down to the cord. But when the new bushings go in, its like every nut and bolt in the entire car has been retightened.
Great product.
Old Sep 9, 2013 | 07:53 PM
  #40
WayMotorWorks
Vendor
Great product.
We know you beat on your car at the AutoX too.
Old Feb 13, 2014 | 11:08 PM
  #41
Ministrater's Avatar
Ministrater
2002 MCS
Installed last April and could not be happier. Great improvement in steering sensitivity and handling. After 10,000 miles as a daily driver in brutal highway and city traffic no issues whatsoever.
Old Feb 14, 2014 | 02:58 AM
  #42
jamez's Avatar
jamez
I've got a local member that has a new set of PF LCAB's for sale, but it doesn't come with the grease. Can anyone tell me what the grease is and if it's special, where I can get more?
Old Feb 14, 2014 | 08:15 AM
  #43
v10climber's Avatar
v10climber
Supposedly copper antiseize works but I use the stuff from Hotchkiss that is designed for Poly bushings...http://www.hotchkis.net/14_oz_super_grease.html
Old Feb 20, 2014 | 01:08 PM
  #44
espedaire's Avatar
espedaire
Originally Posted by Dielectric
I did the PF lower motor mount reinforcement at the same time, NVH at idle with the A/C on is quite nasty, but how often am I sitting still?!?
@Dielectric or @Way
Is there a picture of how the reinforcement washers (Powerflex Control Arm Bushing Reinforcement Kit) go in? What I want to know is whether I need to pull the control arm off completely to tap it, or do they go onto the bracket instead? Pulling apart the control arms is kinda intimidating... whereas the brackets are already out and ready to be drilled/tapped.
Old Feb 20, 2014 | 06:19 PM
  #45
WayMotorWorks
Vendor
It is actually a copper grease, many times it is mistaken for being copper antiseize but it is not the same thing. We can get you a tube of the powerflex copper grease if you need it.
Originally Posted by espedaire
@Dielectric or @Way
You can tap them on the car, but we never install the supports as we've never seen a difference with them.
Old Feb 22, 2014 | 12:45 AM
  #46
Melangell's Avatar
Melangell
No issues at all with the front. Just ordered rear trailing arm bushings from you.
patsum
26
May 29, 2021 06:29 PM
Norton70
Sep 7, 2015 05:06 PM
Gen1Parts
Sep 7, 2015 03:50 PM
Gen1Parts
Sep 7, 2015 01:37 PM
Sep 3, 2015 12:24 PM
