Is my Oil Pan missing screws?
Old Apr 21, 2007 | 05:05 PM
vano's Avatar
vano
This evening, just before taking off to meet my buddy, I did my usual fluids/ground check to make sure nothing out of the ordinary was going on with the car. I noticed that there were a couple of drops on the ground. I immediately got the car on the ramps and noticed that there was some wetness on the underside of the car. I noticed that the oil plug wasn't tightened to spec and cranked it down using a torque wrench. I topped the oil off and drove around to make sure all was well.
With day light running out, I looked around the area one last time to make sure I found the root cause, but then I noticed that the oil pan had a few screw holes in it, with no screws inside. One of these screw holes had a fair amount of fresh looking oil around the opening.
Is every screw hole on the oil pan supposed to have a screw in it?
I included a picture of the oil pan from www.realoem.com -- the red dotted lines indicate where the screw holes with no scres are. Can someone tell me if this is normal? Thanks in advance.
Old Apr 22, 2007 | 07:51 AM
techtipz's Avatar
techtipz
There should be screws in every hole.
Old Apr 22, 2007 | 07:56 AM
joey1320's Avatar
joey1320
have you recently had the gasket replaced???
there should not be any holes unused.
Old Apr 22, 2007 | 04:31 PM
vano's Avatar
vano
The oil pan was recently removed to be cleaned. I am thinking a few screw holes were missed when it was mounted back in.
SheldonCooperS
Aug 25, 2015 11:57 AM
ShadyCoop
Aug 24, 2015 06:05 AM
Lex2008
Aug 16, 2015 08:33 PM
minipopkart
Aug 13, 2015 05:22 AM
eliseo1981
Aug 6, 2015 05:00 AM
