Oil in coolant problem
Old Mar 12, 2007 | 12:51 PM
  #26
vano's Avatar
vano
Yup... I remember the S2000s blowing a few engines for a little while when they first came out. Granted its a much more complicated and highly strained engine than in the MC, still even japanese cars have engine problems sometimes. From what I can tell (and this is just my experience) Americans make some pretty bomb proof engines. The reliability falls short in other areas much more than the engines.
If the issue is a blown gasket, I think its just bad luck. There are 1000s of MCSs running around with aftermarket pulleys and I don't think I have heard of any blown engines so far. (MC does run higher compression though).
Old Mar 12, 2007 | 01:03 PM
  #27
vano's Avatar
vano
Originally Posted by caminifan
Not necessarily. The fact that your coolant recovery tank was bone dry could indicate that the engine was operated without enough coolant sufficiently long for the block to crack. I don't know if these cars have a low coolant level sensor or not (to warn that the coolant level is low). But even if they did (have a low coolant level sensor) and the sensor failed, you could have had the coolant level get progressively lower and lower until the head gasket blew and with continued operation, the block cracked. If your head gasket is blown, you have had something happen. The path from blown head gasket to cracked block is pretty short.
I don't want to sound pedantic, but I have never been one to completely trust electronic sensors. Which is why at each fill-up, I visually check the engine oil, coolant and brake fluid levels.
My recovery tank was not bone dry. If I said something to indicate that, I should probably change it. The recovery tank was right where it should be, but the problem is that at the bottom of the tank (about 1/4 of the tank) had this chocolate sediment stuff. So the fluid was there, but some of it was contaminated with oil.
I am not saying its impossible that the block is cracked, I am just saying its not very likely. Still, I will ask Eric to closely inspect the block as well, better safe than sorry. (Knowing him, he probably has this covered already)
I am not saying that the block can't possibly be cracked or the head isn't warped. I am just saying that given the way I drive and how often I check
Old Mar 12, 2007 | 03:35 PM
  #28
Dr Obnxs's Avatar
Dr Obnxs
You'll know soon!
And the block is pretty robust. As for the sediment in the overflow tank, that's not an issue. One of the reasons it has baffles is so that dusty stuff can settle out there. Every tank I've looked at has had some.
The oily stuff is still a problem...
Matt
PS, I lost a head gasket and overheated. Both the head and the block were fine.....
Old Mar 12, 2007 | 09:10 PM
  #29
caminifan's Avatar
caminifan
As Dr. O says...
The oily stuff is the problem. If it does not return after the head gasket (or the heat exchanger) gets replaced, then life is good. If it returns, then it is time to think new short block.
Old Mar 17, 2007 | 11:53 AM
  #30
vano's Avatar
vano
Update
Eric and I decided to flush the cooling system and run the car for a few 100 miles to see if more oil leaks into the coolant. It has now been 100 miles of semi-spirited driving and the coolant tank is super clean, not a hint of "milk" or browning. It is a little bit below the MIN tick mark that I don't think it is leaking, the guys at Helix probably accidentaly put a little less coolant in than they intended to.
I'll keep a very close eye on the coolant consistence, color and levels for the next 500 miles or so. If I don't see any changes, we will call the problem "fixed" and move on. I'll post another update in a few days.
Old Mar 17, 2007 | 01:55 PM
  #31
gizzer777's Avatar
gizzer777
Best of luck with it
I hope all is well Vano...hope you also got my PM.
BTW: this is the first auto (now sold) that I ever saw sediment in the coolant tank...of course i always changed coolant at every 2 yr intervals on my other autos...Blah to the Mini extended service BS. Do they care if you blow it up after the warrantee is over...NOT...God do those guys need a few class action suits....Defects or quirks...latent defects too! I decided to get rid of mine BEFORE anything major happened...When the PS fan siezed, I made up my mind since had i not seen it when winterizing, things could have gotten really ugly this summer...Must admit I miss my ex MCS!
Kimolaoha
Jul 5, 2023 01:04 PM
Cereall
Sep 5, 2019 06:05 PM
danielbrookes_9
Oct 3, 2015 12:51 PM
tylewis
Aug 18, 2015 06:53 AM
kwijmbo
Aug 5, 2015 09:00 PM
