Dome Lights Burned Out
Old Mar 7, 2007 | 07:44 PM
napptym's Avatar
napptym
Our 2006 PW MCS is now dark inside.
I think the Dome Lights burned out.
The car is about 3 mths old.
Odd.
Everything else is great.
Should I fix it myself or take it to the dealer
Old Mar 7, 2007 | 07:46 PM
mjgmcs1's Avatar
mjgmcs1
Same with mine. I'm about 500 miles from my first service and am just going to wait until then to get it fixed.
That is odd.
Old Mar 7, 2007 | 08:19 PM
chows4us's Avatar
chows4us
Odd.
You could get 100 MINI mechanics to change them for your. One to change the bulb and 99 to twist the MINI around
Old Mar 7, 2007 | 08:21 PM
ChrisW's Avatar
ChrisW
If you live close to a dealer take it in, If not do it yourself its easy.
Old Mar 8, 2007 | 04:40 AM
buzzsaw's Avatar
buzzsaw
If you push and hold the dome light button while it is illuminated and continue holding it after it extinguishes, it will stay off until you manually turn it back on. Just a thought.
Old Mar 8, 2007 | 09:32 AM
napptym's Avatar
napptym
thanks for the tip.
i'll try it tonight.
Old Jan 7, 2009 | 07:33 AM
sailnavy's Avatar
sailnavy
Replace Dome Light
Replace Dome Light?
I have a 2003 MCS and the Dome light stopped coming on when the doors are opened. Does anyone know how to change the bulb? I know it should be an easy question, but thought I'd ask before I go tearing into the car.
Also, what button is being referred to that will turn off the dome light, perhaps I've activated it accidently. I thought the buld was burnt out a couple weeks ago, then it mysteriously started working again for a week, and it's now dead again.
Thanks!
Old Jan 7, 2009 | 10:23 AM
Gil-galad's Avatar
Gil-galad
See chowsie's guidance in Post #3 ...
Seriously, the dome light cover just pops off. A small, flat-bladed screwdriver helps to push in on the edge of the plastic cover to free the tabs. The bulb just pops right out of its copper contacts if you pull on it. The button in question is the dome light button itself...the one located at the front-middle of the dome light cover.
Or, for added fun, you can replace it with one of these:
http://www.gominigo.com/LED-interior-light.html
You can do it.
KrisMiss
Jan 3, 2016 02:02 PM
danielbrookes_9
Oct 3, 2015 12:51 PM
scottrn
Aug 22, 2015 07:26 PM
Aug 19, 2015 12:51 PM
