Shallow 36mm Socket featured in this month's RSpeed How-tos
Old Apr 16, 2003 | 09:36 AM
ThumbsUp's Avatar
ThumbsUp
I've read all the post here regarding a search for a shallow (enough) 36 mm socket for the oil filter can. I've also searched the web, and just find the usual stuff.
But this month's how-to features a perfect tool. Who makes it? Where can I get one?
BTW, I'm looking for this particular socket. I already have a Craftsman 36mm socket.
Thanks.
Old Apr 16, 2003 | 10:20 AM
friedduck's Avatar
friedduck
That's a Hazet socket. After Googling I found this place that sells them.
The part # on their page is HZ 2169-36 and it goes for $27.69.
Hope this helps,
Jeff
Old Apr 16, 2003 | 12:06 PM
MGCMAN's Avatar
MGCMAN
I found a Husky brand shallow 36mm at Home Depot in my area. Price was under $7.00. Works fine with my 1/2 drive ratchet. I'd be afraid that there would be too little space for a socket, 3/8 to 1/2 adapter and ratchet between the filter and the firewall though.
Old Apr 16, 2003 | 12:14 PM
chrisneal's Avatar
chrisneal
The Craftsman does work, with this limitation: you can only loosen the canister about one full turn before you run out of room to remove the socket. From that point, it's loose enough to remove by hand. Obviously this has something to do with the height of your ratchet head as well, but this is what happens with mine.
Old Apr 16, 2003 | 01:11 PM
ThumbsUp's Avatar
ThumbsUp
>>Hope this helps,
>>Jeff
EXCELLENT. Just what I was looking for. THANKS!!!
Old Apr 16, 2003 | 07:02 PM
flyboy2160's Avatar
flyboy2160
the 5 piece stanley set p/n 85-733 also has a socket that works with a 1/2" drive. about $9 for the whole set at walmart...and it even looks like flank drive!!
Old Apr 19, 2003 | 06:05 AM
ThumbsUp's Avatar
ThumbsUp
I checked out the Stanley set at WalMart, and for the money, this is the way to go. The set cost $12.97 and includes the 36mm as well as 32, 30, 28, and 27mm sizes. The 36mm is 2" in length. I tried it with every 1/2" drive ratchet I own, including a Craftsman torque wrench, and the clearence to the firewall ranged from 1/4" to 1/2" - more than enough to get the job done.
BTW, these ARE flank drive sockets. This was a bargain. Thanks for the tip.
blackie
Jan 18, 2017 09:56 PM
minicoclub
Aug 25, 2015 09:07 AM
FLYM1N1
Aug 16, 2015 01:17 PM
Emnotek
Aug 13, 2015 05:47 PM
