Valve cover leak
Old Sep 23, 2006 | 09:25 AM
norm03s's Avatar
norm03s
Valve cover leak
Went out to change spark plugs @ 49,300 and find #1 cylinder has oil in bottom of spark plug well. At the top I can see oil around outside of well.
This can only get worse.
Going in for warrenty work, anyone else have a leaking valve cover gasket?
Old Sep 23, 2006 | 09:52 AM
Califzeph's Avatar
Califzeph
Not on the MINI, but on every Dodge I ever owned. You can keep tightening down the valve cover, forever compressing the gasket, or get the gasket replaced. A good choice for you since it's under warranty still. The gasket is usually good for at least 100K miles. You must do a LOT of driving!
Old Sep 23, 2006 | 10:25 AM
norm03s's Avatar
norm03s
Tightening down
Isn't the cure for sure. The only way is replacement.
It is leaking from the top of the well, not real heavy but enought to wet the spark plug base. All the others are dry and the plugs still tight.
A July 29,2003 delivery with almost 50,000 isn't to bad, been fun since day one.
By the way #1 plug color looked real good.
Anyone else had to have valve cover gasket replaced???
Old Sep 23, 2006 | 10:46 AM
Gromit801's Avatar
Gromit801
Ok, time to dig out the old competition trick I used on my MGB. MGB's use a cork valve cover gasket, which leak, and tend to self destruct upon removal. In that instance, I used Permatex (#6 I think) to seal the gasket to the valve cover, and anti-seize compound on the side of the gasket that sealed to the cylinder head. Zero leaking, and the gasket didn't rip apart whenever I needed to pull the cover off.
With a Mini VC gasket, use anti-seize compound on both sides of the gasket. Anti-seize is thick enough to block oil leakage, and never hardens, and is very easy to reapply after removing the VC. Doesn't melt under engine heat either. Some SCCA road racers have used anti-seize on head gaskets (That's who I learned this from).
One more point: Never use a silicone based sealant on gaskets with direct contact to oil. Oil will eat the silicone, leaving a stringy, leaking mess. I do not know if synthetics will have the same affect. Save the silicone for water pumps and thermostat housings. In oil areas, I use the pliable, non-hardening Permatex. The brown stuff, #6 I think the number is, but check that before buying.
Old Sep 23, 2006 | 04:09 PM
norm03s's Avatar
norm03s
Thanks for the tips but this is on MINI.
Old Sep 24, 2006 | 06:07 PM
Gromit801's Avatar
Gromit801
The entire second paragraph of my post concerned Mini's.
Old Sep 24, 2006 | 06:14 PM
mitchman's Avatar
mitchman
Did you even read his post? I thought it was very informative. What more do you want?
If your car is still under warranty, take it to the dealer. Shesh!
Old Sep 24, 2006 | 06:32 PM
Rawhyde's Avatar
Rawhyde
Basic mechanical techniques are applicable on MINIs even if first learned on Chevys, Fords, or even MGBs. Great post Gromit! I've never thought to use Anti-Seize on a gasket. I'll remember that one!
Rawhyde
Old Sep 24, 2006 | 06:57 PM
Jeremy1026's Avatar
Jeremy1026
Moderator
thank god for warrentys huh. your best bet is to have it replaced, every quick fix is bound to fail sooner than a complete re-do
Old Sep 24, 2006 | 07:09 PM
Gromit801's Avatar
Gromit801
Not necessarily true. To use the anti-seize method, start with a new gasket, and it will last you longer than you can imagine.
09R56
Nov 16, 2022 10:49 AM
PaulWalliDumali
Aug 21, 2015 04:46 PM
Lex2008
Aug 16, 2015 08:33 PM
OutMotoring
Aug 6, 2015 09:32 AM
eliseo1981
Aug 6, 2015 05:00 AM
