What Is This Leaky Part Under My Hood?
Old Aug 16, 2006 | 07:50 AM
martoon's Avatar
martoon
I noticed that something under my hood recently went leaky and I have no idea what it is or what caused it. Since I'm beyond my warranty, I was hoping you might be able to help me out. Any idea? thanks!
https://www.northamericanmotoring.co...1&d=1155739555
Attached Thumbnails What Is This Leaky Part Under My Hood?-img_1.jpg   What Is This Leaky Part Under My Hood?-img_2.jpg   What Is This Leaky Part Under My Hood?-img_3.jpg
Last edited by martoon; Aug 16, 2006 at 07:55 AM. Reason: left something out of the headline
Old Aug 16, 2006 | 07:52 AM
mdsbrain's Avatar
mdsbrain
Engine Mount. Yours has failed and should be able to be replaced under warranty.
Old Aug 16, 2006 | 07:54 AM
vsmini's Avatar
vsmini
hydraulic vibration damper. have you noticed it idling a little rougher?
Old Aug 16, 2006 | 07:55 AM
CarterMD's Avatar
CarterMD
Uh.... looks bad !
This is the motor mount engine damper and as you can see it is an oil based damper !
You should replace it quite fast... otherwise your engine-vibrations will get transfered to you chassis *brrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrr*
Old Aug 16, 2006 | 07:57 AM
martoon's Avatar
martoon
Fast Repiles!
wow, you guys are fast. thanks for the quick tips. I'll contact my dealer right away. I wonder if that's covered under my warrenty beyond the 50k. Guess I'll find out.
Old Aug 16, 2006 | 08:00 AM
mdsbrain's Avatar
mdsbrain
It maybe up to the dealer if they will replace it with the car being over 50k.
Old Aug 16, 2006 | 08:01 AM
CarterMD's Avatar
CarterMD
Well, a friend over here in Germany got the same problem and BMW fixed it for free and his car was nearly three years old. So if you got a well and fair dealer it should be no problem.
If not, the part should cost something about 70$.
Old Aug 16, 2006 | 08:08 AM
martoon's Avatar
martoon
i'm calling princeton mini now
let's see what they say
Old Aug 16, 2006 | 08:19 AM
martoon's Avatar
martoon
They said there's a two week if I schedule an appointment. I guess I'll have to have it towed in.
Old Aug 16, 2006 | 04:09 PM
apexer's Avatar
apexer
That may get them to repair it sooner or, they may just let it sit for a week.
Plus you'll probably kill any chance of getting replaced under warranty.
I'd just schedule an appointment. Probably won't hurt anything to drive it until then. Just don't hammer it.
Old Aug 16, 2006 | 04:19 PM
DarkMiniCooperS's Avatar
DarkMiniCooperS
That "new" engine damper's design doesn't look that good...
I've seen a lot of MCS back in Montreal with that problem...
Old Aug 16, 2006 | 05:29 PM
volki
You should see the old one (02-05). It looks like it is being held together by a shoelace (just picked one up this morning for my 03 MCS - should have taken pictures). Although not as common as the new design, the old ones leak as well...
Old Aug 16, 2006 | 05:52 PM
DarkMiniCooperS
Really??
I thought 02-04 are rubber?
Old Aug 16, 2006 | 05:59 PM
Johnna's Avatar
Johnna
Clean it up quick
Once you've shown it to your MA, see what you can do about getting it cleaned up. I've heard that the stuff is a real bear to get off after it's had a chance to settle in.
Old Aug 16, 2006 | 06:00 PM
volki
Really??
Here is mine. Although rubber, they are oil-filled. Got it replaced today while getting a WMS 15% pulley.
PS: Dont feel bad... Service Adviser told me the same thing
Old Aug 16, 2006 | 06:07 PM
DarkMiniCooperS
lol I don't feel bad.
I was asking a question. When I'll get my car back, I'll check mine.
Thanks for the picture!!
Old Aug 16, 2006 | 06:34 PM
volki
...When I'll get my car back, I'll check mine. ...
Hope you'll get it soon (I am following your thread)...
Good luck!
Old Aug 16, 2006 | 06:38 PM
DarkMiniCooperS
Good luck!
lol thanks!!
Getting it soon is one thing...
Getting it working #1 is another...
I just hope they'll fix it right, and that I'll be nejoying the LSD ans 05 gear ratio soon.
Old Aug 17, 2006 | 05:46 AM
Spitfire's Avatar
Spitfire
Hey I just noticed a puddle under my car this morning. Popped the hood and my damper/mount is leaking as well. My car is an 05 with 26k miles so it is for sure going in under warranty. Problem is I am 300 miles from home and will not be returning until October (though the car will be sitting from this Sunday until then).
Is it ok to drive it until Sunday, then park it, then drive it 300 miles to get back home?
How does this happen?
Old Aug 17, 2006 | 06:18 AM
Squirlz's Avatar
Squirlz
I don't think it hurts anything. I drove thousands of miles after first noticing mine leaking before I could get it replaced. I couldn't feel a difference between the old part and the new one. Maybe it hadn't leaked out completely?
Old Aug 17, 2006 | 06:38 AM
Larry Clemens's Avatar
Larry Clemens
Are they replacing the leaky one with the same design?
Old Aug 17, 2006 | 08:47 AM
Spitfire's Avatar
Spitfire
I just called the Service dept at Detroit Mini and asked if I could, by some miracle, get the car in today or tomorrow to replace this. Of course they were booked until the end of August but it was worth a shot. I asked her (service advisor) if I could drive it with the leaky mount and she advised against it. Unfortunately I have no other option.
Oh well, I hope it doesn't cause another issue.
Old Aug 17, 2006 | 06:39 PM
volki
I think it depends on how much it leaked out - as you mentioned. Mine must have been completely empty to the point where I "realized" that the car was shaking unusually when starting it the first time. Moreover, taking off at lower rpms (unintentional) exhibited rattles from the engine compartment (engine rattle being transferred to the chasis). Apart from these annoyances, I dont think it hurts anything either.
Good luck with the repair!
Old Aug 29, 2006 | 12:52 PM
pauliekeys's Avatar
pauliekeys
I'm wondering how many Mini's have had this problem and if there is any after market part that would be better. I just discoverd the leak this morning on my 05 Mini S after noticing an oily substance doted all down the pasenger side of my car as well as the boot totally coverd with the what looked like oil. My car is pepper white and when I was washing my car I noticed that this stuff was not coming off. Could'nt clay bar it,couldn't get it off with Z5 cleaner wax. Made an appointment with the Dealer this morning to fix it and told them that they would need to get this stuff off as well as fix the part obviously. After talking with Octainguy I might hold off on there bodyshop trying to get it off and wait for Octainguy to look at it.
Old Aug 29, 2006 | 12:58 PM
05DSMCS's Avatar
05DSMCS
I'm pretty sure this is a known issue, as WRR discussed the fact a while back that they have redesigned replacements for the failed mounts. So it's not to the point that they are recalling them, but they are replacing them with redesigned parts.
