Does your MINI shudder?
Old Aug 10, 2006 | 06:20 AM
skillet's Avatar
skillet
I've noticed lately that my '03 S shudders when I turn it off (probably doesn't like the idea of sitting still ) It seems to be every so often, not all the time. It does it with the AC running or not... but I have found that when I shut it down as I'm coasting to a stop, it doesn't seem to do it.
Also, sometimes when I turn the car off, it has this "knocking" sound. Is this normal?
My car has 85000 miles on it (bought it with 75000), and I haven't replaced plugs or anything of that sort. I do oil changes religiously, and had a 15% pulley and intake put on by Webb @ 82000 miles...
Thanks!!
Old Aug 10, 2006 | 04:21 PM
trico's Avatar
trico
Change the plugs, but I would say spark is likely not the problem. I would bet on a need to re-program the ECU, or use of bad gas or a timing problem. What octane do you use? Name Brand? How much ethanol, if any? Have you had a tune-up since the addition of the intake and pulley? Did you re-program the ECU to account for the reduced pulley and increased airflow?
Old Aug 10, 2006 | 04:31 PM
royal4mac's Avatar
royal4mac
My Mini doesn't shudder, but my passengers do!
Old Aug 11, 2006 | 05:16 AM
skillet's Avatar
skillet
I'm hoping it's the plugs as I would like to go with some aftermarket ones..
The gas I use religeously around here is Citgo (will soon be switching to BP), 93 Octane ( a couple of weeks ago, I about ran out of gas and had to throw 91 in it), I don't think Citgo has switched to an ethanol yet...I'm still running the stock ecu, and I don't know when it had the ecu update, if any at all.
Is there a way to check and see what version your car is running without having to take it to the dealer?
Thanks!
Old Aug 11, 2006 | 07:02 AM
Rich B.'s Avatar
Rich B.
Ck motor mounts.
Old Aug 11, 2006 | 08:47 AM
skillet's Avatar
skillet
What should I be looking for? Just loose in general?
Dec 23, 2015 10:36 AM
Dashdog
Aug 10, 2015 06:17 AM
Aug 7, 2015 05:56 AM
Aug 7, 2015 05:55 AM
