Chasis flex/Sunroof Creak
Old Jul 10, 2005 | 08:33 PM
  #51
inmimini's Avatar
inmimini
creeking noise
yes i see the same issue pulling out of driveway sounds like comming from sun roof.
Old Jul 11, 2005 | 03:07 AM
  #52
reefkid's Avatar
reefkid
I'll be getting the sunroof rails greased this week and report back. It doesn't happen often enough to be concerned but I'd rather it not happen.
Old Jul 11, 2005 | 06:33 PM
  #53
driver centric's Avatar
driver centric
Sounds good reefkid. Good luck and let us know how it works for you.
Old Oct 11, 2005 | 01:29 PM
  #54
kaelaria's Avatar
kaelaria
reefkid - did it work? Mine is annopying me now so I'm going to try a greese myself - if it doesn't work the dealer can try in a couple month at the first service.
Old Oct 11, 2005 | 06:27 PM
  #55
BigKart's Avatar
BigKart
Creaks
The latest issue of Road & Track says that they had hatch creaking with their car and fixed it with a new latch. I think they also had door alignment issues. I have a non-sunroof MCS and it creaks, too.
IT also has the most irritating noise somewhere in the dash near the center. I have no idea what it is, but MAN is it persistent! (Suggestions?)
Old Oct 11, 2005 | 06:42 PM
  #56
npartist's Avatar
npartist
Mine used to do it ('03 MCS w/ sunroof) when new but has since stopped for quite a while now (34k miles). I have notice thought that i have two distinct depressions on each side of the roof beside where the two sunroof glass pieces meet (ie about 3/4 toward the back of the car). They are hard to notice by looking but running your hand along the roof (the part on either side of the sunroof) you can easily feel them. I call it a mini quirk...
Old Oct 12, 2005 | 01:59 AM
  #57
reefkid's Avatar
reefkid
They greased my sunroof with no noticeable improvement. I haven't had them try anything else recently but I need to have my mini steering wheel logo replaced for the third time soon and I'll have them take a look again at the creak.
Old Oct 13, 2005 | 07:30 AM
  #58
J0kER's Avatar
J0kER
grease will not man the problem d0oD! u have to trim sum of the plastic diverter piece.....it worked for me...dealer greased mine everytime i went in for sumthin' else & it never lasted long enough for comfort
Old Oct 13, 2005 | 08:06 AM
  #59
fdavid's Avatar
fdavid
Sorry started reading through but don't have time to read them all now.
YES! My MCS 05 (born in April 05) does the squeak noise when coming out of the driveway as well. Very sharp noise but I never thought that was an issue.
So what’s the final prognosis, anyone figured out what' happening?
Thanks guys.
d
Old Oct 13, 2005 | 09:01 AM
  #60
reefkid's Avatar
reefkid
What's a plastic diverter piece? Can you describe it any better? Thanks.
Old Oct 13, 2005 | 09:24 AM
  #61
J0kER's Avatar
J0kER
it really isnt a big huge deal other than its a pain in the *** to listen to if its that loud mine isnt loud but have heard them loud ones & its not cute...
its jus cabin flex & normal on sunroof mini's but like i said its not loud at all in mine so dont know how to tell u!!!!
Thanks guys.
d
Old Oct 13, 2005 | 09:28 AM
  #62
J0kER's Avatar
J0kER
l8ter g8tor
when u open the roof if u hear it at this point then the trimin' of the diverter/ will help its the piece that scrapes on the inside of the roof openin'
its black plastic...& u have to look at it closely to figure it out as far as where to trim it!?!?!?
i will look at mine closer to get better description/its been rainin' here alot
Old Dec 30, 2005 | 07:48 AM
  #63
RED FURY's Avatar
RED FURY
Originally Posted by goldcountrymini
I have a 2004 and I have the same problem. Were there any results of the dealer experiences? I would be interested to know.
Yes, it is TRUE ....
Creak and noise would not go away ... had it to dealer twice, not fixed first time, they adjusted some things at first, just got it back!!!
Sunroof frame replaced under warranty, due to "flexing"
Old Dec 30, 2005 | 07:19 PM
  #64
UKSUV's Avatar
UKSUV
This is what happens when my sunroof flexed
Old Dec 30, 2005 | 07:22 PM
  #65
UKSUV's Avatar
UKSUV
From my educated guess: The moonroof casette is not that stable and from my research, there have been several windshields and moonroofs exploding due to the tempered glass. Mine was the first in a Mini, though.
Old Dec 30, 2005 | 07:38 PM
  #66
eVal's Avatar
eVal
The roof looks really dark in the photo, was it tinted?
Old Jan 1, 2006 | 12:27 AM
  #67
UKSUV's Avatar
UKSUV
Nope...Well, not as far as I know. I had the dealership tint the windows but I'm sure the moonroof was not an option. It was pretty dark but my new one is just the same.
Old Jan 1, 2006 | 08:51 PM
  #68
J0kER's Avatar
J0kER
Wow.....
did this happen under heavy load or sumthin' ?
mine makes noise when i drive up or down my drive way.
i now run a rear brace & it has stoped!!
Old Jan 2, 2006 | 12:56 AM
  #69
UKSUV's Avatar
UKSUV
Nope....Just driving down the freeway. I have noticed that I have flex in the moonroof and the rear hatch. Whenever I go over something at an angle, these two things make a LOUD pop. Has been like that since it's birth.
Old Jan 2, 2006 | 08:34 AM
  #70
J0kER's Avatar
J0kER
thats not normal.........
will the dealer cover u under warranty???
get a rear cabin bar, they really werk!!
Old Jan 2, 2006 | 09:02 AM
  #71
sequence's Avatar
sequence
I notice torsional flex whenever I corner agressively (like thru a roundabout) but all it does is make my crackling dash rattle worse in my early build 05 S.
Old Jan 2, 2006 | 07:46 PM
  #72
UKSUV's Avatar
UKSUV
I'll do that whenever I get around to it. I'm actually trying to cage my car right now. I'm in a so-so mood about my Mini. I use it as a daily driver and want to track it so bad. If the motor drops-out, so be it. I still keep it nice though. As for your question....they upgarded the latch mechanism but it still does it. I thought it was my RSM's or a drop link but all seems well. As far as the replaced moonroof......well, MNS did a real crappy job with the install. This is one of my only grips with the dealership. I still find glass and what-not in the track. Plus, you can tell they didn't align it right because with it open something plastic rattles around so bad that I usually close it. I'm at the point with the Mini to say, "Whatever."
Old Jan 2, 2006 | 09:29 PM
  #73
J0kER's Avatar
J0kER
sorry to hear that bro.
it sux that a lot of these dealers suk at small details... ....itry not to let them mess w/mine to much, jus dont trust them.
i have a crack on my wind screen and im sweatin' the day that i have to get it replaced dont even trust the people that do the replacements on these, i do most of what i can do myself.
hope it werks out tho, the cage sounds k00l!! whos will u use?
Old Jan 3, 2006 | 12:10 AM
  #74
UKSUV's Avatar
UKSUV
Most likely Autopower but I am reading that SCCA might change the cage specs soon. So, I might hold off.
Old Jan 3, 2006 | 09:25 AM
  #75
OldRick's Avatar
OldRick
If you believe you have symptoms showing chassis twisting or flexing, consider injecting foam into the frame to make it a bit more rigid. It's cheap and seems to help. Have a look at:
https://www.northamericanmotoring.co...ad.php?t=54848
