Blown Spark Plug!!
Old Jan 3, 2006 | 04:10 PM
  #51
1FSTMINI's Avatar
1FSTMINI
Originally Posted by BigBrownDog
Do you mean:
Comec - Commission on Missing and Exploited Children
Hell yea....We'll open a sweat factor and make them all heliciol our heads.
Old Jan 3, 2006 | 05:43 PM
  #52
jlm's Avatar
jlm
oops!
Old Jan 3, 2006 | 08:51 PM
  #53
k-huevo's Avatar
k-huevo
Cometic Gasket 1-800-752-9850, BMW-MINI COOPER 78.5mm/.027" MLS HEAD GASKET Part #C4308-027 $83.95 (3/05)
Old Jan 6, 2006 | 01:44 PM
  #54
1FSTMINI's Avatar
1FSTMINI
I might be getting a customers head with bad threads on one of the plugs
ill be def sending it out for some polishing and bigger valves.
Old Jan 6, 2006 | 07:23 PM
  #55
crzycpr's Avatar
crzycpr
I appreciate everyone's comments on this issue. I have decided to replace the head, have it ported and polished and switch the stock cam to a schrick cam. I am still undecided as to which plugs to put in it. Seems there is a lot of controversy on the Densos. Any suggestions?
Old Jan 7, 2006 | 07:58 AM
  #56
BMDoubleU's Avatar
BMDoubleU
well, i run densos and havent had any issues... (they were installed by randy at webbmotorsports.com . if you choose to go with any new spark plugs just remember to have them torque down to 20lbs.. also, no need to re-gap..at least on the densos)
good luck.
Old Jan 7, 2006 | 10:19 AM
  #57
LombardStreet's Avatar
LombardStreet
Moderator
Originally Posted by Rawhyde
[snip]
FREE TIPS:
1. Don't remove a spark plug from an aluminum cylinder head unless it is COLD. If you do it hot, or even moderately warm, you can pull the threads right out of the head.
2. Steel screwed into aluminum sets up galvanic corrosion. Put it in at 20 ft-lb and you may need over 100 ft-lb of torque to remove it later on. USE ANTI-SEIZE when putting a steel fastener into aluminum. Let me repeat that for emphasis. USE ANTI-SEIZE when putting a steel fastener into aluminum!
Rawhyde -
Thanks for the tips! I've been using a torque wrench for sparkplugs for a long time, but didn't know about the temperature problem nor using anti-seize. Thanks!
Old Jan 7, 2006 | 11:04 AM
  #58
BuckeyeMCS's Avatar
BuckeyeMCS
Not that it matters but Ford has the same/worse problem with the 5.4.
It happens with even the OEM plugs installed at the factory. They won't pay a dime and it is a very common problem. Strange thing the new 3V 5.4 has more threads for the spark plug. The original had just 3 treads
Old Jan 7, 2006 | 11:58 AM
  #59
Wagnbat's Avatar
Wagnbat
I've been reading that over at the f150 forums. I have an F150 too and was cross searching the plugs when I was trying to troubleshoot some engine/lifter noise.
Luckily, had my '01 F150 5.4 since '02, and no blown plugs.
Old Jan 7, 2006 | 07:13 PM
  #60
Rawhyde's Avatar
Rawhyde
Originally Posted by LombardStreet
Rawhyde -
Glad to help!
Rawhyde
Old Jan 8, 2006 | 09:34 PM
  #61
Dr Obnxs's Avatar
Dr Obnxs
Excellent hint from a friend...
to get all the little bits of metal out before you helicoil a head on the car, stuff pantyhose into the cylinder. Every little bit of metal will get caught, and when you pull them out with some hemostats, no more shavings!
Matt
Old Jan 8, 2006 | 09:39 PM
  #62
Eric_Rowland's Avatar
Eric_Rowland
Good hint, Matt. But now the dilemma - risk metal shavings in your cylinder, or try to explain to your wife why you're taking her pantyhose out into the garage...
Old Jan 9, 2006 | 03:49 AM
  #63
jlm's Avatar
jlm
another tip for the helicoiling in place: turn the crank so both vavles are closed and the piston is just below TDC about 1". this will help prevent a chip from getting under a valve.
Old Jan 9, 2006 | 06:32 AM
  #64
Dr Obnxs's Avatar
Dr Obnxs
Third hint...
Take wife or SO out to a nice dinner. When she ******* that she just ruined a nother pair of hose with a run from a toenail, stash those in the toolbox....
Matt
Old Feb 13, 2006 | 04:07 AM
  #65
IsItElectric?'s Avatar
IsItElectric?
Well this weekend I've finally removed the head en route to a helicoil in cylinder #2. I've decided to go with the stock head gasket and some Bosch Platinum 4's instead of the Denso's. Hopefully this will help with the spark plug issue but I'm going to torque them down every month for sure. This was a pain...
I also need to remove my 15% pulley to qualify for STX...
So...as promised...here are some pictures. It's been over a month since I've driven the car and I can't wait to get it all back together. It's unbelievable how much crap I had to remove from the car just to get the head off. All this to avoid metal chips in the motor....a lot of work but now at least I know more about the car.
Other mods I'm doing before autox season include front camber plates, Schroth harnesses, and I'm going to look for some Koni's possibly.
Anyone got any advice for putting it all back together? Everything looks pretty standard so it should go well. I'll post some more when its back together...
Attached Thumbnails Blown Spark Plug!!-dscn0081-1.jpg   Blown Spark Plug!!-fscn0076-1.jpg
Old Feb 13, 2006 | 12:20 PM
  #66
neilgj's Avatar
neilgj
It appears that getting the right torque on the plugs is important and the damage associated with under-torquing is clear. What are the issues that an over-torqued plug will cause?
Old Feb 13, 2006 | 01:13 PM
  #67
haulinS's Avatar
haulinS
what?
are you kidding me? now I have 2 cars with plug issues....great.
Old Feb 13, 2006 | 04:32 PM
  #68
SwingMCS03's Avatar
SwingMCS03
When I clicked on one of the pictures in post number 65, I got a blaster type virus. Heads up!
Old Feb 13, 2006 | 05:04 PM
  #69
kapps's Avatar
kapps
Yikes! Good heads up for those poor Windowz users.
Old Feb 14, 2006 | 03:17 AM
  #70
IsItElectric?
Really?/! That's odd....nothing happened when I use them....and I brought all my pics to work and still nothing odd seemed to happen.
Old Feb 14, 2006 | 05:43 AM
  #71
SwingMCS03's Avatar
SwingMCS03
Well, I'm tempted to try it again but I'm not going to. I just know when I clicked on one of those pics, my computer instantly gave me a warning and highly recommended I shut down my internet connection.
Now back to rebuilding that engine. Good luck. I have a hard time finding the dipstick and reading the dang thing.
Old Feb 14, 2006 | 06:29 AM
  #72
1FSTMINI's Avatar
1FSTMINI
nothing happened to me
Old Feb 14, 2006 | 06:35 AM
  #73
mdsbrain's Avatar
mdsbrain
No problem here. Make sure you are up to date on windows updates and antivirus.
Old Feb 14, 2006 | 08:26 AM
  #74
Wagnbat's Avatar
Wagnbat
I could be wrong, but I think it would be updated anti-virus giving you the warning, while un-updated antivirus wouldn't catch anything.
Old Aug 18, 2006 | 12:20 PM
  #75
TonyB's Avatar
TonyB
Just thought it wise to revive this thread as I believe many might not be aware... Seeing this thread in the Performance Forum, had me thinking that this might be prudent:
https://www.northamericanmotoring.co...ad.php?t=76773
Having had an aftermkt top mount IC blocking access to the spark plugs, I wasn't checking as often as would otherwise. I recently installed the DFIC top mount, and decided to check them as this unit doesn't cover the plugs, and 3 were loose!!! I had last checked 3 months ago, and torqued them to 21 ft-lbs, using anti-seize.
Just a friendly reminder...
