Supercharger Belt Squeel on new MCS?
My fiancee and I just purchased a brand new 2005 MCS Coupe prem/sport/LSD. We test drove the car before buying and it came w/ 6 miles on it, took it around for 10 miles and noticed a loud squeeling coming from the front. At first I thought it was the wheels, but when we got back to the dealership they said it was the s/c belt.
When we rev'd the engine in neutral it did indeed squeel with a higher pitch as the rpms went up, which seemed logical to me that its the belt. They said they've had other customers w/ brand new MCS have this noise and once the belt is broken in after ~400 miles it should go away.
Well we drove it home 200 miles from the dealership and its probably louder now at appears at every rpm when on the throttle. I'm ready to give it another 200 miles but things aren't getting any better. Is this normal, is there anything else that could be a problem than the belt itself?
Originally Posted by Angus
Same problem, brand new MCS 2005. Dealer put on a JCW Belt and that fixed it or it is just masking the problem?
FWIW, sever people have found that the alternator becomes, or is, slightly out of alignment, and can cause this squeek and abnormal wear.
Its a real bear to get too. You'd have to pull the whole front bumper and radiator assembly to get to all the bolts that adjust the alternator. If you're in warrantee, get the deal to fix it.
Originally Posted by xizor
1000 miles on it and the sound has largely gone away, but it still shows up now and then and is still quite annoying. I'm taking it in for checkup next week, we'll see how it goes.
Originally Posted by camelpilot
You may have the wrong size belt on (sorry i cant remember which, but someone here on NAM had this problem - and had a good dealer that realised this). A few 05 MINIS have had this problem. Maybe your POS dealer knows this now. Call them and find out.
Shouldn't it just work with a normal belt. Makes me wonder if the fix is just masking a bigger problem.. but maybe I've just got my knickers in a twist about nothing??
Mine started sqealing in the first 100 miles on the way home from the dealer. It only occurs when the car has warmed up and it's worse on hot days. I was hoping it would go away, but after one week and 1100 miles, it's still there and getting worse. I have an appointment at the dealer on Monday. I should have 1700 miles by then. At least it's consistant and unless the "gone by 1500 miles" is correct, it should still be there.
Steve
Steve
Steve
Steve
Let me know what you find out... Although they fixed the squeal by fitting a JCW belt.. I'm not sure if that's the right fix.. My guess is that the squeal is being caused by the belt slipping. If the belt is slipping perhaps a component on the belt is not moving as freely as it should and by simply putting on a tighter belt you end up forcing the component to move. This doesn't sound healthy to me.... but I'm not a mechanic.
Whatever the root cause, MINIUSA must know by now that this is not a one off. I'd expect them to have gotten to the bottom of this. If they have and there's a specific fix, then I'll take mine back to the dealership.
Angus, I believe the JCW fix may be the correct one in this case. My tensioner looks to be maxed-out. It is almost touching the the S/C pulley and doesn't look like it can get any closer. The shorter JCW belt will pull the tensioner away from the S/C pulley giving it a chance to work. At least that's my theory.
Steve
Steve
Exactly my experience. Did not do it from a cold start. Was worse on hot days.. did it more in start/stop traffic.. Infact if I went straight from a cold start onto a highway, I could stay on the highway for an hour and the squeal wouldn't appear until I exited the highway and got back into start/stop traffic.. 2mins later and it's back.
Steve
Steve
If the JCW fix is the correct one, then what happens if I fit a reduction pulley. Many people prefer using the JCW belt with a reduction pulley to avoid belt slippage due to a shorter path. Won't I be back to square one if I go with a reduced pulley? I'd hate to see a true warranty problem from preventing me from doing what would otherwise be a pain free mod. Something is simply wrong that prevents this from working problem free with a stock belt.
Steve
Just went for a 2 hour fun run. It's definitely a squeal, not a squeek (like a bearing) as I'd previously thought. I had my fiancee rev the car while I popped the hood and listened. Definitely seems like it's the SC belt.
It is *LOUD* too. Ambient temp indicator read 74 degrees; we were cruising with the windows down. I'd say the noice is about halfway in between "really frickin annoying" and "hellaciously offensive".
Like an '82 Cutlass Sierra fan belt really.
Yep, I posted the same problem like 2 weeks ago. I picked up my MCS and after 100 miles it started squeeling. It is really loud when its hot. My dealer told me that they are going to change the supercharger and I am waiting for the parts as they have several cars with same problem (?). I picked up mine in June 30th. Is it in late 05's or all 05's get it???
Hi everyone,
I've been lurking on NAM for sometime and this is my first post. Just got back from Classic MINI with my 14 day old MCS. Their fix to the squeak/squeel problem was to "Remove Tensioner mounting bolt and lube bushings and tensioner"
Classic did the fix during lunch time while I waited. So far so good!
