R52 Horn relay location
Old May 16, 2025 | 02:16 PM
solomio's Avatar
solomio
2006 MCS convertible. Can someone please tell me where I can find the horn relay? I checked the driver's side fuse box (found the fuse). I also checked the engine compartment fuse box (where most relays seem to be) and still can't find it. Anywhere else I can look? I had a situation today while driving and the horn starts honking for no reason intermittently. Then it started honking continuously. Pulled over and pulled the negative battery cable and waited a while which did not help. Pulling the fuse helped. Figure I'll check the relay next.
Old May 19, 2025 | 06:33 AM
mrbean's Avatar
mrbean
It's on the driver's footwell fusebox - but it's mounted on the back side so you have to remove the whole thing to get at it.
Someone can correct me if I'm wrong, but I believe it's soldered in place. So best of luck!
justenx_1
Apr 3, 2023 03:14 PM
bonnietiler
F54 :: Clubman Talk (2015+)
Apr 13, 2021 12:52 PM
lanevomr
May 12, 2010 06:53 PM
Wassim
Aug 29, 2008 10:50 AM
EmCeeEss
May 6, 2004 05:37 PM
