Desperately need help!!!
Old Dec 16, 2024 | 12:58 AM
MadMiata's Avatar
MadMiata
This is what happened... It idled a bit weird at a light, high at 1000 rpms and as i turned it bogged down and wouldn't go over 10 mph in both automatic and manual modes. Wuz gonna limp home but then i started to see a little smoke and something smelled funny so i pulled into a parking lot and saw little sparks coming from past exhaust. Had it towed home and checked the codes the next day. This is what i got....
P1688EWS elec. Immobilize system
Fault codes: 6
FF general reset x 5
0F power on reset
ABS/ACS/DSC
5 codes
5E16 CAN connection to instrument cluster
5DF4 System voltage <9v
5E19 CAN data fault from DME/DDE (DSC lamp on as long as error present)
5E15 No message, transmission (EGS 43F or SSG 43G)
MRS multiple restraint system
2 codes
0B safety battery terminal
71 Seat-occupancy detector, passenger
IKE/IKI/KOMBI instrument cluster
3 codes
51 Fault in transmission management
6C CAN bus, no DME message 1
92 MRSZ5: malfunction in airbag system
ZKE Central body electronic
14 codes
00 Internal fault in control unit: internal voltage
RAD Radio
04 Drive: hardware fault
Any and all help is greatly appreciated! The car starts fine also. The CEL, airbag, and DSC lights are also on.
pkx
Nov 22, 2014 05:40 PM
thecanuck
Sep 18, 2010 02:59 AM
weaverpsu
Dec 23, 2009 12:03 PM
Maxicooper
Dec 22, 2006 02:09 AM
