Harmonic Balancer from Hell
Old Aug 22, 2023 | 03:43 PM
coldrolledsoul's Avatar
coldrolledsoul
Following the mod mini method I placed a cut off bolt in the center of the HB, used a crowfoot puller with an impact gun to get started. There was no problems sliding out the HB for the first 1/4". I then slide a longer bolt into the center, reattached my puller but haven't been able to get any more movement out of damn thing. I've tried tapping it with a light hammer while using the impact and tried a combo of impact gun + 19mm wrench on the puller but I cant get any more thread moving. The car is a 2006 MCS
Also bolt in the center seems bound up on something - it can wiggle and 1/4 turn easily with your fingers but I cant pull it out anymore with vice grips. I've been at it for 5-6 hours but I just cant get this one figured out and would really appreciate any ideas to help get this sucker off.
Old Aug 24, 2023 | 03:41 AM
Here2Go's Avatar
Here2Go
NAM Community Team
Although I haven't encountered this problem - Have you tried re-seating the pulley in a bit, spraying PB Blaster (or lubricant) and then giving it another try at removal? - You may have to carefully repeat the process.
Or is that what you've already tried.
I've also heard of others having to use a MAP torch to heat up the pulley in order to get it off.
Old Aug 24, 2023 | 03:57 AM
Daftlad's Avatar
Daftlad
Used one of these bad boys with no issue.
https://www.minimania.com/part/NME59...-Gen1-Cooper-S
Old Aug 24, 2023 | 04:14 AM
Here2Go's Avatar
Here2Go
NAM Community Team
^^^That is the same puller I used = Good tool/puller.
Didn't have or used the installer though. 'also looks like a useful tool
Old Aug 24, 2023 | 07:38 AM
coldrolledsoul
Thanks for the help - Ill try reseating and going at it again + torch and blaster.
Old Aug 24, 2023 | 01:47 PM
coldrolledsoul
Hit the pulley with the torch for about 5 minutes and it slide off like hot butter!
Thanks again for the advice
TG.
Jun 12, 2022 08:52 AM
booyah93
Dec 31, 2019 07:36 AM
JRoze
Jun 11, 2017 07:00 AM
RedAndBlackMiniS
Aug 14, 2012 06:03 PM
Miniphyter808
Tires, Wheels, & Brakes
Mar 4, 2003 06:01 AM
