R53 no start just 1 click
Old Jul 29, 2023 | 09:25 PM
Margarita Man's Avatar
Margarita Man
SOLVED.....53 no start just 1 click...SOLVED
SOLVED.........R53 2006.
symptoms as above.
Dash lights up.
Have a spare starter but would prefer to eliminate other issues before swapping.
Battery good. Started my other mini.
Found no voltage at positive terminal in engine bay! What would limit this?
fuses all ok.
Just a click on start.
100amp fuse in boot at battery is fine
Cheers
Old Jul 29, 2023 | 09:39 PM
jcolletteiii's Avatar
jcolletteiii
Check the big main fuse on the battery. Did you do any work recently and maybe not reconnect a big ground strap?
Old Jul 29, 2023 | 09:48 PM
Margarita Man
Big fuse on battery is fine. Voltage both sides
Battery fuse in boot is fine.
no work done.
I don't think the starter power goes through that fuse.
Old Aug 5, 2023 | 06:40 AM
Boostmaster's Avatar
Boostmaster
This is going to sound weird, but I encourage you to try it. It will only take a couple minutes.
Disconnect the ground strap on the passenger side motor mount. Even if it's like new, go ahead and hit it with a wire brush and reinstall. Then try to start car.
I fought with a starter for over a week. Same issues. Finally tried this as suggested by other Mini owners and it worked!
Old Aug 5, 2023 | 04:46 PM
Margarita Man
Solved.
The thickest wire from the battery connection system (not fused) runs directly to the starter/engine bay..
It inserts into the battery terminal are which is covered by black plastic. It worked it's way loose ,. Just seems to be push in?
Just poor.connecrion
Old Aug 7, 2023 | 05:24 PM
Onizukachan's Avatar
Onizukachan
If you mean the battery connection. Under the black plastic at the battery terminal is sliding back and forth, there is a good chance the 3xplsive charge went off amd that’s why it is loose. Take the plastic off, drill a hol3 thru the concentric conn3 tron and insert a sheet metal screw to keep them together. Assuming it didn’t click back into place.
jecamp988
14
Jan 12, 2023 11:29 PM
CT Hiker
Jul 21, 2021 08:05 AM
Realwebbs
Jan 10, 2019 07:53 AM
delsurviajero
Feb 15, 2018 11:12 AM
FrankR53
Sep 28, 2011 11:37 AM
